DC amps, what are the options?
Largely for testing purposes i need an amplifier with flat frequency response between 0 and 80khz.
But most amplifiers do not have a flat frequency response, most have a filter that will mess up measurements below 10hz (including most expensive ones).
Do i have to buy an amplifier and modify it or is it any good option where that isn't needed?
Build your own with the Apex Microtechnology PA04 power op amp.
Circuitry is simple and DC is no problem. Just omit input coupling caps.
Not cheap, but it will work.
I'm working on a sub amp that uses four of these.
I've also built amps with its little brothers, the PA07 and PA12 power op amps.
Reactions: stevenrotterdam
I see PA04 can supposedly do 200V and 20A peak which is massive overkill (4000W DC, 2000W AC)
PA07: instead offers 100V and 5A which is 250W AC.
Ill look into these 2. I was hoping to find some decent pre-build option but i guess that just doesn't exist.
Those are peak values and you never get the full PS voltage across the load.
My PA07 amp does 75 Wrms into 8 ohms continuous and the PA12 amp does 125 Wrms into 4 ohms continuous.
The PA04 amp isn't up and running yet but the data sheet conservatively estimates 400 Wrms.
What you do get largely depends on the power supply capacity / regulation.
My design philosophy has always been "overkill is better than performance limitations".
Best of success!
Reactions: vintologi
I cannot spot any anti-DC filter here:
Looking at the manual it seems like the Cc capacitor will affect how high frequencies the amplifier will reproduce but i don't see anything regarding low frequencies.
Have you considered high powered prosound amps, like the Crown XLi 2500, for example, which is 750Wrms per channel into 4 ohms and sells for only about $550 here in the USA.
Seems like that's easier, cheaper and quicker than a build.
Ill look into them but accurate frequency response is more important than high wattage for the project.
And where does the DC requirement come from when testing subs?
What anti-DC filters does is to filter out low frequency sounds.
The benchmark AHB2 for example seems to have a first order high-pass filter at 0.1hz which while less problematic than most competitors is not something you actually want if your subwoofer can handle these very low frequencies just fine.
I have also read that some amplifiers will outright shutdown if there is is too much high intensity of low frequency signals in order to 'protect' your speakers (which usually cannot be adjusted or disabled).
That would be the DC fault protection to prevent the voice coil from going up in smoke.
One could change the time constant so that it doesn't trip at very low frequencies but it would be quite slow to act in case of real DC on the output terminals.
