can anyone offer help understanding the flow of this circuit
If you want to troubleshoot this thing you need to take a bunch of voltage readings until you find something wrong. If the there is a big DC offset at the output then the input stage should be trying to correct for it. Is it? If it is, then follow to the the next stage to see if the transistors there are responding to the correction signal from the input stage. At some point the correction signal will get lost or become ineffective. You need to find where that point in the circuit is.
hello rayma, i have removed every semiconductor on the board and tested them with a peak transistor tester and double checked them with the diode function of my dvom. they all tested good. i have also tested all the diodes 1n5004.1n5003,1n4150 ..also tested and replaced all the zener diodes 1n4742a i have tested all my mosfets with the peak transistor tester and with a diode check between the drain and the source..all showing open, then i touch the pos + lead to the gate and then the mosfets showed contuinuity.......after that i discharged the mosfet with my finger and there was no connection from drain to source.
Never directly touch the gate, since the voltage breakdown can be as low as 20V.
Failure may not immediately occur, but can happen later on due to weakening of the gate structure.
Have you tested all the other parts? What about the continuity of the device tabs to the sink?
Have you fixed that? Are there isolation pads?
Start with both working and non-working PCB, turn them copper side up and measure between each solder point and compare voltages. Start at the input and work your way to the output. Remove the FB resistors on both so that you don't find the output on the inverting amp input, they should both be held a zero volt. It may be better to pull both inverting and non-inverting input through a resistor to ground, so they are physically at zero volt.
The amplifier never came with insulators . The mosfet had thermal paste and directly mounted to the heatsinlks. What do you mean by device tabs to the heatsinks? I don't understand.
Post photos of the removed output devices, on both sides.
It appears they have TO3 cases, which need isolation with (usually) mica insulators.
Their metal case IS the collector/drain terminal.
The mosfet test was something I learned on YouTube. What would you recommend now that the mosfets have been removed. I am sure the problem is on the board and nothing else.
It appears they are TO3 which need isolation with usually mica insulators.
The insulators are absolutely necessary except in certain very rare types of construction.
Otherwise all of the collectors/drains of the output devices (both positive and negative)
are directly shorted together by the heat sink.
