Speaker Protection Board
It’s there and not there - can’t order / ship out of Germany….
For the new Nad design replacement board it seems to be able to work for positive offset , not for negative, unless there is some others circuit which is on the board and since amp service manual i can’t find where this new design was given, not sure how this would work.
@Bonsai , is it possible to run the board from a +15V auxiliary supply and also using the aux supply's 15V AC?
And if so: Can I use the same resistors as for 20V?
I would need to connect the aux GND to the main supply GND in an appropriate way, right, e.g. using a 1k resistor?
EVRERY job is a job for a microprocessor these days (For those that hate coding, sad but true - queue Metallica here).
Somebody will just have to make some cute little PCB kit with SMDs that directly plug in where the old IC did. People are resorting to that to replace STK modules, often making something BETTER than the original - and there are boards for sale IIRC. The UPC1237 replacement might sell more, having a wider market. Pre-assembled for a few bucks more, perhaps.
Reactions: Vrystaat and aditya
Something like this:-
Protection/Amp Management features
•Amp Output DC offset protection
•Amplifier overcurrent detection
•Amplifier oscillation detection (> 1V pk-pk at >50 kHz)
•Mains in-rush current limiting control
•Speaker enable delay (5 seconds) on power up, fast (<25ms) disable on power down using mosfet solid state relay. Requires access to transformer secondary AC
•Speaker enable/disable using supply voltage detection – can be used with class D amplifiers
•Heatsink overtemperature monitor – trip at 65C and reset at 55C
•Main power ON/OFF relay control if used with standby PSU (~1W at 5V) allowing use of low voltage power switch
•Amplifier clipping indicator
•Tri-colour LED status indication
So all these functions would be on the controller, but you could put it into a circuit and only use the ones you wanted, for example
•Amplifier overcurrent detection and trip input
•Speaker enable delay (5 seconds) on power up, fast (<35ms) disable on power down using mosfet solid state relay. Requires access to transformer secondary AC
To make it fail safe, you trigger a monitor cycle every mains zero crossing (10ms for 50 Hz, 8.33ms for 60 Hz) an arrange it so the controller resets if trigger doesn't come within say 2 ms of when it should.
The expense in these uController approaches is usually in the additional cost of the power supply and ancillary components around the controller. Nevertheless, I'm surprised NAD aren't going down this route since they already have a controller to do the remote and you can always prioritise the amp protection over everything else.
I have seen Pioneer monitor the AMP supply and Regulated supplies for a error to turn the amp off. but not so in Base level Yamaha like 202
I've designed a simple speaker protection board using the UPC1237 (Unisonic Taiwan is the manufacturer, originally uPC1237 from NEC) that uses mosfets rather than a relay to switch the speaker. The circuit operates from 25V to 75V with some resistor changes (detailed in the write-up), features power up/down muting, DC offset protection and an input to trip the protection on overcurrent (you will need to arrange your own short circuit detection - the board just takes an input for this as a trigger).
There's a presentation with the circuit, BOM and if you want a board, you can buy one off the website.
Hifisonix Speaker Protection Board
Happy soldering
Hello Bonsai
The link provided on the top floor has no longer worked~
One of the builders has had a problem with his board in which he could not get the AC detect to work. We even suspected the UPC1237 to be at fault. However, he discovered it worked when he moved the AC detect input to a different secondary winding. I did a quick sim to look at the secondary AC voltages wrt his issue and have identified the problem - I should have seen this earlier, and as a result of his experience will have to add some additional notes to the build instructions.
Here is the test circuit - note the voltages Vac1 through Vac4
Here are the voltages Vac1 through Vac4 wrt 0V
What you can see is that Vac3 and Vac4 are effectively pushed down so they swing from ~0V all the way down to -40 V peaks. So, he was connecting to Vac3 or Vac4 on his build and that's why it did not work.
You can only link to Vac1 or Vac2 in split secondary power supplies like this that first rectify and smooth each rail before combining them otherwise the Speaker Protection Board AC detect won't work. Alternatively, you can wire a 2.2uF film capacitor in series with the AC detect and that will also work on any of the windings, but I think the best solution is to just stick to picking up connections Vac1 or Vac2 as shown here
Apologies to anyone else who had this issue and my thanks to Michael and his girlfriend for solving it! 🙂
For split rail power supplies that use a single bridge rectifier like that shown below you can take the AC detect off either Vac1 or Vac4 :-
Reactions: aditya
Hi Bonsai,
For my mono block amplifiers I will be using one PCB for each channel, what do you recommend:
  • use both DC protections in parallel for one channel
  • remove one optocoupler and its mosfets and use only one
