Need opinions on my PCB 3-stage amp design. Will it work?
I need some reviewing if my PCB design for this 3-stage 15W amplifier would work with my component placement. This is the 2nd PCB I have designed and would etch it myself. I am designing it in KiCAD
I got gaps behind the large transistors since I would be attaching heatsinks there. The three medium sized transistors are the driver and the VBE multiplier in the middle. The large ones are the output ones, I do not know if it is ok positioning those two resistors behind each of them.
Not good PCB, potentials will race on the ground as they wish. Non-RC filter on input will give hard oscillations. Try not to use polygonal type of ground if you can't imagine/know the current's map.
sorry. 🙄
I don't see place for heatsinks. And outputs transistors are too close to each other... 🙄
I am sorry, I did not understand the terms. wdym by "potentials will race on the ground as they wish". Also, about the input filter I am thinking the R1 and C1 highpass filter at Q1's base is not adequate?
You do not need the output cap unless you are afraid of DC when something goes wrong in the amp.
The output cap C7 I need it for a different reason. When I do not have it the quiescent current on my output stage would be imbalanced for a bit. For example, the current through R20 is 70mA but there is 65-68mA through R21. But when I added C7, they become almost equal.
Replacing R16 and R17 with a PCB potentiometer would allow you to adjust bias current practically. I just need to warn you that in a simulation all the components are perfect and in practice not. Being able to make adjustments on the fly is a smart thing to do.
For the sake of a last comment, I would place decoupling diodes between the power devices and the front end and feed power near the power devices. This is because you do not want the power supply to be modulated by the music current.
