Something to lighten the mood
My Italian friends say cheese is the only topping allowed. Everything else is illegal.
Homemade pizza disaster last night. Despite large amounts of semolina sprinkled on the metal pizza-peel, the pie stuck and wouldn't release onto the hot stone in the oven. Suddenly the menu changed from pizza into calzone, which turned out to be, I'm relieved to say, delicious.
Note to self: always, ALWAYS put the dough disk on a large piece of baking paper for topping and assembly. Then paper+pizza onto peel and carefully shimmy the paper+pizza onto hot stone in the oven. After ~ 4 minutes of baking, the bottom crust has solidified enough to let you remove the paper.
I knew this, I wrote this on my recipe card, but somehow I failed to do this. Again. Note to self: don't do this.
Reactions: Pano
I must be doing it wrong. I roll the dough on a floured board adding more till it stops stretching back so much. I then lay it over an oiled holey pizza pan, trim it, add the toppings and place it in the oven. No concerns with transfering or having to use parchment paper.
You guys are going to have to head over to the Food thread and show me the light.
Here's some of my failures. You should see the ones that came out right.
Everyone says, and I believe, that pizza peels made of wood are superior to those made of metal. They release pies into the oven / onto the stone, first time and every time.
However the pizza peels offered to me by Amazon are much wider and deeper if I choose metal rather than wood. So I tolerate the greatly increased probability of dough-stuck-onto-peel from metal, smug and secure that this issue is easily bypassed with baking paper. It's not a problem if you know the solution beforehand.
However baking paper does nothing beneficial when you omit it. As I did (as I often do) last night. Grumble. Do as I say, not as I do.
