Big JBL TL-250 on steriods project
Im planing to soon use my earlier diy cabinetts, it´s built like a larger JBL TL-250 model.
My plan for end results is a 4-way sound of "older" jbl-sound.
Will be using these drivers:
JBL 2235H up to ca 150 hz
JBL E-145 150-6-700 hz
AGA CD driver with "Baby butt" massive horn 6-700-7000 hz ( 20-25 kilo each horn)
JBL 2405/077 supertweeter 7000hz and up
The total volyme in the cabinette is around 160 liter, which approx. 130 liters is a separate box.
Baffle is 80 mm thick.
And my ide is to use the E-145 mounted in front baffle ( where the ordenary woofer sits), and make a separate chamber about ca 20 liter.
And make a new hole at the back of the cabinette for the 2235h, working in about 110 liters.
Is the volyme for both E-145 and 2235h sufficient ?
I have played a little in Winisd and for the E-145 litervolyme both with vented and closed box, but don´t seems to matter that much if used from 150 hz, or is im wrong ?
Now the 2235h used in JBL B380 subwoofer uses 127 liter
What do you think about my project hifi people ?
/John
Reactions: Arez
I use that woofer combination E-145 and 2235 and it works quite well. I have the E-145's in 5 cubic Ft tuned 40 Hz and the 2235's in B 380 clone cabinets tuned to 26 Hz using a BX-63A driving them with the Q2 +6 db bump filter. Crossed at 80 Hz.
Those cabinets are nice. Never saw the horn before, what is it made out of?? I have my set-up in standard cabinets. Also using a different top end 2123 10" mid and a 2453 SL on a PTH1010. I used to have 2344 horns with 2426's.
Should be nice when you get it all together.
Rob 🙂
Reactions: Arez
Wow Rob, that setup looks to have great qualification to "top-sound"
How high up are you using the 2235h and E-145 ? ( is it a 4-way speaker?)
The JBL 2453 SL is 113 dB, how you level the system?
You have a nice volyme of 141 liters for the E145 and 226 liter for the 2235h.
I wonder how my E-145 will work in only 20 liter from 150 hz?, and if i have to rebuild the cabinette so the 2235h have larger volyme to work in, or if 110 liters is sufficiently.
In my cabinette i have about 26 liter volyme above the 130 liter, so maby i need to rebuild it so i´ts 156 liter in total.
The "baby butt" horn is build of many layers of thin chipboard, carved and worked on many many hours.
And i have a "damping layer" of special-bitumen-mix, between the CD and the horn ( to avoid any resonances)
But i think i will paint it in black matte finish.
Nice to se your system Rob 👍
/John
Hello John
Thanks, It is an active 4 way 80 Hz, 300 Hz and 1.5 Khz are the crossover points. When you use your box program check the VAS value. It's not correct in the tables. I am attaching a thread on the E-145 that explains why VAS s/b 428. The E-145 likes a big box so plan accordingly. The 2453 uses a passive pad and the CD compensation is also passive that helps match the driver levels.
Rob 🙂
https://www.audioheritage.org/vbull...-The-purpose-of-JBL-E145/page2&highlight=e145
Reactions: jawen
Hi again Rob
Is VAS really important when using the JBL E-145 from 150 hz and up?
I was thinking VAS "only" matters when you want to build a low frequency box aka "subwoofer" build.
Okey, so you onlt use the 2235h up to 80 hz, why not a little higher up ?
And then you use the E-145 from 40-300 hz, so both E-145 and 2235h working together between 40-80 hz?
And the 2123 from 300-1,5 K.
How long is your listeningdistance ?
I just love the sound these older JBL papercone speakers produce, voices, aukustic guitars etc...It´s like the "real thing"
And when i was given the chance to buy these JBL drivers from a 80 year old gentleman here in Sweden, i couldent resist.
Original owner bought around 1990 never used them more then a little testing and in original boxes with same serialnumbers both or the 2235h, E-145 and 2405/077.
How big chance is that nowaday´s
I also try 2 times to registrate on audioheritage.org before, but newer get an answer from administrators.
And today it say´s " Sorry, registration has been disabled by the administrator"
And Rob.....Do you own Urei 801c ?
/John
Hello John
It will shift the F3 by a few hz and I knew it was wrong so why not use the right value.
They are both crossed at 80 Hz 24 db L/R active crossover. I get the best blend between the drivers there.
Yes 300 to 1.5K I am close 8-9 ft I like them as well!
Reactions: jawen
You were lucky take good care of them original re-cone kits are getting harder and harder to find!
Yes there is a forum issue going on. Yes I do own an 801 C used it as my center channel for years.
Rob 🙂
Reactions: jawen
Fantastic!
I have read a lot of the Urei.
In 2000-2003 or so i bought a newconed JBL 2215h ( without knowing it´s specs), from Sound of Singer in New York.
And sometimes trought the years i have put it on the floor on pillows pointed at me, just to play through a 200 hz filter, and every time a was so impressed over the sound. ( and think its the best ive heard from 200 hz)
And when i Google it i se it was only used in the Urei 813/815 speaker.
/John
Greets!
Technically, based on these E145 specs and assuming some series resistance, age, etc., that lowers its upper mass corner (Fhm); yes.
Can't really interpret your post GM, can you try explain it in a simpler way.
As like to a newbi....English is also not my native language, and hifi have so many "technical words" which is not used particularly often in ordinary contexts.
Weighed the horns today, a whopping 31.5 kilos each "baby butt"
/John
So i have "built" a liittle, and it was real trickey to build a "inside" separate box for the JBL E-145.
Because 2 walls are inclined on my DIY cabinette( like JBL TL-250 ), so several different angles to saw out on the same small mdf pieces
It end up at about 28 liter netto for the E-145, but change my mind about mounting the JBL 2235h at the back.
Better mount it at left side of the cabinette, both for design and functon ( if the speaker is placed near frontwall )
Tuned the 2235h to around 28 hz, and that needed 2 x 100 mm port 472 mm long to come near the 160 cm2 port area that JBL recomend.
Also re-paint the JBL 2344a clone horn ( baby cheek) to mattvblack with matt clear coat.
Had 2 ports low in the box from before, but coulden´t use more then one of them because of the leight of 47,2 cm port needed.
So re-buildt the topp of the cabinette to be able to have one of the port at the highest point, over the JBL 2405h.
Trickey but do-able and 2 new pieces of mdf had to be made and painted. ( also paint the screws black after photo)
So tomorrow i can begain to measaure the 4 separate drivers, so i can begain to build a xover.
But i have one cabinette more to finish...and 20 hours of work to get it ready.
Best regards John
Understood. Click on the embedded 'technically' and specifically the 'horn loading' link for a complete list of definitions and where along a speaker's response each apply to and if still don't understand you can either ask specific questions here or probably better to contact a forum member posting in horn design related threads 'flying your flag' for help.
The E-145 VAS numbers will agree with TS calculators, at around 427L not 247L 🙂
It has been mentioned on audioheritage forums several times, also from other sources.
Erronous spec sheet numbers from JBL.
Also have read many times about the "error-VAS value in JBL E-145 spec, so my wdr files allready have corrected VAS value 431,99 in text-file for the E-145
Do the JBL E-145 VAS value mentioned, changes/mean anything in my ca 28 liter netto volym box for the E-145 using it from about 150 hz and up?
Slowley trying to learn knowlege about speakerbuilding, but up to this day i only thought VAS was importent for subwoofer/low-woofer builds regarding to box-volymes, tuning and SPL.
Regards John
Again, yes, since its upper mass corner is ~35 Hz x 2/0.255 Qts = 274.5 Hz where T/S theory peters out, so for it to NOT matter at 150 Hz, Qts would have to be ~ > 2 x 35/150 = 0.467.
Reactions: jawen
Can´t find a embedded "technically" on this site ?
So i need to go up to 275 hz you mean? ( 2 x 35/275 = 0,255)
I dont have skills for this type of knowlege`, so can you explain to me why the driver need to be > 2 x 35/150 = 0.467.
And what "happends" if the driver is Qts 0,255 but sits in 28 liter netto and used from 150 hz ?
Best regards John
This word in my post has an embedded link........can't you see the lighter, different color of such links?
Ahh now i can see it!
Its night here in Sweden and i have some program in my computer called f.lux that changes the screen after the sun/daylight here in Sweden ( take away eye-stimulation blue light etc)
And i can´t see it with the f.lux aktivated, but no when you told me i disable the program and then i can see it.
https://justgetflux.com/
Will read it GM 👍
Regards John
Reactions: GM
In the linked thread is the 'horn' embedded link.
No, this is just the upper limit of the box's T/S theory derived response and above this point/frequency it's solely based on its inductance, so if none inputted it will flat line off the end of the chart.
You'll need to have a good 'grasp'/basic understanding of T/S theory first.
That's what making a sim is for, i.e. shows how the box's acoustic properties alters/shapes the driver's. 😉
