ARTA 1.9.6
I am glad that you all help me in testing with different soundcards.
I will continue to analyze those small instability that mainly comes from soundcard driver transient; i.e. on first measurement, on change on sampling frequency, on change of soundcard etc.
(Some programs keeps driver open long before the measurement, and maybe that is way to go) .
Soon I will add measurement of longer PIR duration to enable measurement of T60 larger than 12s.
For those that downloaded ARTA 1.9.6. I recommend that you do it again, as I did not refreshed sweep start frequency in analysis of distortion.
Thanks,
Ivo
Thanks,
Ivo
Just an observation: The position of the left cursor (yellow) normally at 'Home' ie 300 samples, makes some difference in the frequency response result in the above shown tests. I tried from 0 to 300 and it varies by roughly the same amount as the sweep variations.
To &JanRSmith:
sample position 300 is reference for zero time. It is chosen as modern sigma delta converter generate pre-ringing which we can treat as ringing in negative time. That is why we always have to put cursor bellow sample position 300. (Usually 30-60 samples bellow). This time shift givers proper magnitude response but adds additional phase shift (which can be compensated by setting as Time delay for phase calculation).
Ivo
Ivo
Joined 2003
Use the ARTA News page as a guide to determine the date of release for the version you are interested in.
https://www.artalabs.hr/news.htm
Then goto the internet archive and browse to nearest date after the release.
https://web.archive.org/web/20220901000000*/https://www.artalabs.hr/download.htm
Version 1.9.5 can be found here:
https://web.archive.org/web/20220920150120/https://www.artalabs.hr/download.htm
I tried and it worked well.Use the ARTA News page as a guide to determine the date of release for the version you are interested in.
Thank you
Now, the last version of ARTA software compatible with Windows XP can be downloaded from ARTALABS Install section.
Best,
Ivo
Best,
Ivo
It works great under Linux WINE, so I assume it will also work great with MacOS.I wish I could get ARTA to run on macOS.
I'm still running High Sierra and in the past I've tried to install ARTA under Wine but all attempts were unsuccessful.
300Z : perhaps this is something which can help you? :
https://appleinsider.com/inside/macos/tips/how-to-get-started-with-wine-80-on-your-mac
Ivo, thanks for adressing this. I ran into the same issue during loudspeaker measurements, resulting in what appears to be a DC offset in the impulse response in some measurements. I now have the latest ARTA installed, but I also have a lot of measurements done with the older versions so the DC offset is something that I need to deal with. Is there a way to remove it from existing measurements?
Joined 2003
Hi @timpert , for existing measurements I would recommend processing your PIR files through VituixCAD IR to FR tool. It includes DC offset compensation, by taking an average of the first few samples of dead air in the file and shifting the IR by the offset to compensate.
@DcibeL - I am considering the Motu M2 as a replacement for my Behringer. I am looking for a lower noise, lower distortion audio interface. This device would be used exclusively for making acoustic measurements with ARTA... Assuming the M2 has performance similar to your M4, would you recommend the Motu for use in ARTA?
