Cascode. When to cascode and when not. Your experience? Examples?
This is an example of Hiraga Le Monstre.
He has cascode of JFET in input.
🙂 Stefan
I am working on a power amplifier.
Cascoding of VAS lower distortion considerably.
I guess it's because the non-linear junction capacitance of the transistor is no longer in parallel with the Miller compensation capacitor, but that's just a guess.
When do we cascode and when not?
Whenever it has a big enough advantage to do so. For example, to improve high-frequency behaviour, increase gain, protect a low-voltage device against excessive voltages. A disadvantage it that it costs some headroom and some extra transistors.
Baxandall cascode works very well for cancelling Cob, and will also compensate for the base current of the cascoding device (Q58).
The small bjt can be operated at Vce=0.6V if you choose the right part.
(It's also called Hawksford cascode).
Reactions: lineup
I don't understand where that reference to a JFET comes from, but indeed, for a stage with a load impedance that is small compared to the internal resistance of the amplifying device, cascoding won't increase the gain noticably. It could even reduce it by a very small amount.
Sorry, I was referring to the schematic in post #3. And, yes, in a typical VAS, cascoding gives good results, both regarding bandwidth, distortion and gain.
Reactions: lineup
