Alternative 6 Watt Amplifier with EXICON Lateral MOSFET
Here is the power supply.
You need to have one 2x15VAC transformer 200-300VA.
Then some rectifying diode bridge, say 10A.
Then use 2 of this power supply. One for each channel.
As you can see the power supply output is at precise +/-14VDC.
The difference in this amplifier is differential JFET input.
And also that it works in Single Ended pure Class A.
This means a very low effiency.
Amplifier draws almost 40 Watt to output only 6.8 Watt.
For having higher efffiency you must use Push-Pull and eventually Class AB.
Probably those amplifier you have listened to use that way.
About TO-3.
I will tell PCB files makers to not have transistor onto the PCB.
Instead it will be 3 pads and connected by wires.
Transistor on heatsink and 3 wires to the PCB.
This will make you to use any power transistors.
That sounds great for the pads instead of TO3 being attached to the PCBs. Indeed, all the amplifier I’ve heard using lateral Mosfet were Class AB.
Reactions: lineup
You are lucky to have TO-3 power transistors.
They are great for to handle lots of current and volt = Watt.
They can often have a temperature of 175 degrees, while TO-247 can only cope with 150 degrees.
I am begining to be scared 🤔
One channel uses 38W to put into heatsink.
But there are 2 channels for stereo.
Means that the heatsink will have to get 76W out of the system ....
Can this be done?
I doubt it 😕
Maybe with 2 heatsinks - one for each channel.
If the dissipation at idle is 38W and considering a max heatsink temp of 50C, you would need a heatsink of 0.65C/W or lower for each channel. If you have an old Hafler DH-200 or 220 each heatsink is roughly 0.5C/W so a good match, the heatsink are also build to accommodate TO3...
Reactions: lineup
With a heatsink 1.0C/W and +30 degrees inside amplifier,
there would be 30 + 38*1.0 = 68 degrees one heatsink.
Then we need two of them 1.0C/W heatsinks.
0.65C/W is of course better. As you say +50 degrees.
