Closed cabinet theory—Helium
Alright, let’s get crazy and build (in our mind) a state of the art sealed speaker cabinet and replace the internal air with other gas of other properties, for example Helium.
As sound waves travel differently through different mediums… what would you think the outcome would be?
It would leak the expensive helium away in a few hours.😂
At least until some equilibrium was reached.
That said I guess the speed of sound is higher in helium (I think) so I guess the tuning would be different. Might make the cabinet appear larger.
Reactions: noamgeller
Diffusion, until the internal air became normal air again.
I once tried to seal a woofer, so I could use it as a pump, in a sort of reed valve arrangement. No matter how much seal I put on the cone / suspension, I could not make a perfect leak-less seal. I quit the idea.
I imagine any ordinary driver will leak like mad. But you didnt say slightly pressurized cabinet, with constant flow replenishing...
Smallest after the hydrogen molecule, of course.
Helium will diffuse faster out of a porous container, such as a balloon, than air will diffuse in. 🤓
Hydrogen is the smallest atom, as a molecule helium is the smallest molecule because hydrogen is di-atomic. Hydrogen rarely if ever exists a a free atom. It’s H2.
Helium is used extensively as a leak detection gas for that exact reason for ultra high vacuum systems (electron microscopes, sputtering and CVD systems or cryogenic systems).
