I plugged Sparkos 3601 to dual socket help
I'm afraid I don't follow what you have done...
If you mean you placed a single opamp into a socket that should house a double opamp then there are two possible problems:
1/ You have caused damage to the original equipment. This is easily proved by simply refitting the original opamp.
2/ You have damaged the Sparkos opamp. You can't prove this without testing it in a suitable circuit.
"2/ You have damaged the Sparkos opamp. You can't prove this without testing it in a suitable circuit."
The equipment is working with other opamps. So what should I do with these Sparkos opamps, any way to repair them? I got soldering skills.
is this what your talking about?
did you match the orientation with respect to pin 1?
or did you in fact install a single where a dual should be?
well first we need to know a few things like what is this being used in, as in amp, preamp, tone circuit, or other...
and what the original device was? (chip number??)
and just what terrible mistake did you make?? like installing it with the power on???
Right 👍
So you now need a test circuit or some other suitable equipment to check the Sparkos SS3601 single opamp which is the one you say you have. You could even build a simple standard opamp circuit on a breadboard to test it.
In post #1 you said:
There's an electricity sound coming from the speakers now btw.
I assume that was just with the Sparkos opamp fitted as you say it all works OK with the correct opamp fitted.
You just need to test the Sparkos in a suitable circuit.
