Is This Class-A BJT Amplifier Schematic Worth A Tryout?
Intended to learn simulation, this amplifier schematic comes up. Yes, it's a modification from some schematic around internet. I did use Micro Cap 12 to simulate. The simulation result looks like output power = 21.1W (RMS) and THD is about 0.02% when D1/D2 being 1N4749. The quiescent current for each output transistor is about 975mA, if my simulation is not so wrong.
There is a significant question to be asked here: is this safe to use +/- 19VDC or even +/- 21VDC for NE5532A for listening? because according to NE5532A specification from TI, its absolute power supply is +/- 19VDC.
Is this Class-A BJT amplifier schematic worth a tryout? Do you think there is a better schematic to try? Under consideration of utilizing NE5532A for voltage gain and DC servo, and SC5200/SA1943 as output transistors. BTW, for learning purpose I already used KiCAD 6 to get a PCB layout and routed, about 2.5"x7", not send out for PCB sample manufacturing yet. I know there are so many DIY experienced people around here, that's the reason I am asking. Don't laugh at me.
I can't decide that for you. If you are looking for a not too complicated class A design you can look at Nelson Pass. If you want to design something yourself, reading a book is best start imo, for example the appropriate books of Bob Cordell and Douglas Self
Yes, I am learning including to read the books, which including the Bob Cordell and Douglas Self book. From engineering perspective, why not use the good sound NE5532 or NE5534, also I like Toshiba TTC5200/TTA1943. This push me starting to think how to put those components together.
@anibal
Thank you for the reply. Vbe(Q5) is about 5.2VDC, that's larger than 4Vbe(~3V). Wrong calculation?
Hi Wilson
First of all, I have used pretty similar circuits many times and they work OK, you may think it as an opamp with a power buffer output stage.
Definitely there is an issue and then few details that may improve it.
Regarding the bias, the voltage across Q5 is Vbias=Vbe (R8+R22)/R22; probably the mistake is swapped positions of the resistors.
I do not know your target, I guess the no global feedback is intentional, but if you change R3 taking signal from the output you will get much lower THD.
If you want to introduce a meaningful change in "perceived audio quality" I suggest the following mod:
Remove R27 and replace R10 with a constant current source of about 5 to 10mA, the 5532 has a quasi-complementary output stage (only NPN transistors) so making this mod you will force the opamp to work in class A with only its "upper" output transistor active.
Anibal
P.S.:
If you go for the current source, please connect it to Ve instead of Vee.
R28=4.7ohms has no meaning in the input circuit wired as it is, if you want to keep it to avoid ground loops you should change the connection of R4=680 from GND to the common point of R2, R28 and C1.
Finally, your bias generator is "OK", but it pretty basic and can be improved.
Good luck🙂
Hi Wilson
Anibal
@anibal
Thank you very much for the time writing the detailed suggestions. You kindness and effort are greatly appreciated.
Modification will be taken as 1) remove R28 (4.7Ohm); 2) remove R27 (3.3K) and replace R10 with 10 mA constant current source with connecting to Ve. 3) R8 (500ohm) and R22 (2.2K) will be swapped.
The voltage swing at the output of the NE5532 is to low to drive the emitter-follower output stage. Considering the given Vcc / Vee of +32 / -32V, it's burning energy at no purpose. Even more when run in class A. That's why I wrote you are missing a voltage amplifier stage.
Reactions: Wilson Edwards
