Acoustic Horn Design – The Easy Way (Ath4)
Not all is gold. This is what you can easily get when you're not careful enough. 😱
With the 2 and 4 simulations I'm only seeing differences in the 5-10kHz range. The h results look like numerical artifacts as nothing has changed in this plane and they are at the highest frequencies in the simulation. Its interesting though that below 5kHz I am not seeing differences which suggests it's posible to 'hide' the ports from the HF.
Reactions: camplo
Why do you think that the ports in the upper/lower wall shouldn't affect horizontal polars?
Here's a similar model again, with and without the ports shown.
Without and with the ports (horizontal polars):
Below the non-normalized data, smoothed with 1/6oct -
Horizontal polars:
Vertical polars:
Reactions: kipman725
^ I've often thought that this is worth a try. Almost impossible to simulate a thin sheet of say silk (accurately,) but it could easily be done experimentally.
What about a greater number of smaller holes? I even think I've already seen that somewhere. At what diameter of the individual holes would frictional losses become a real issue?
