I know very little about solid state amps except for looking at the Pass designs and the MoFo.
Those who know a lot more about these circuits might like to make a comparison?
I know. LM334 max 40V According to PDF.Nice!. 2A in class-A - that'll get warm!
But be careful with that LM334 - it's just at the edge of max voltage.
Jan
But there is a drop like 4-5 Volt with the CS MOSFET.
Personally I prefer Sue Parker's topology.might like to make a comparison?
I did not think of that.Nice!. 2A in class-A - that'll get warm!
Jan
In SPICE there is no heat or heatsink 😀
You are of course right.
IRF540 is a TO-220.
It is specified 150 or 120 Watt dissipation. What number varies form PDF to PDF.
At 175 degrees max.
IRFP140 is a good alternative.Better safe than sorry, use IRFP140 instead of IRF540 same chip with TO247 package.
The distortion stays almost the same.
And will take a lot of heat with the IRFP140.
How about the IRFP240?
Would that be suitable?
Sure. But the schematic is not yet complete, still needs provisions to protect mosfet gates and speakers against turn-on and turn-off transient/thump.How about the IRFP240?
There is part variability in the MOSFETs. A pot is necessary at least to start and then can replace with resistors.Its relatively simple to calculate those two R's for mid-voltage - @lineup showed that.
A pot would degrade the reliability with no advantage.
Jan
It would be perfectly alright.Would this work with Exicon ECW20N20? Laterals seem the current favourites?
That model is a rugged device. Takes 250 Watt!!! That is much.
I have some SPICE models of EXICON transistors. But not ECW20N20.
Could we have a link please.Personally I prefer Sue Parker's topology.
jeff
- Tubes / Valves
- Hybrid Single End Power Amp - ECC99 Tube+IRF540 MOSFET >10 Watt
