Korg Nutube preamp noise issue.
Hi all, I’m new here to please be gentle.
Wondering if someone could help me,
my lovely partner bought me a Korg Nutube pre amp but unfortunately I’m having a problem with it.
I followed the diy guide and it works and plays but there is quite a lot of hiss coming through both speakers when it’s turned on, it also gets louder when the volume is increased.
Is there a check list I can run through to try and eliminate it?
Many thanks.
Lloyd.
@Osvaldo de Banfield
Hiss and not hum?
How much hiss... can you hear it with music playing quietly?
please post a series of well-lit, in-focus photos to help the troubleshooting. 🙂
Will have to put it re assemble it again, wiring was as per diy guide, i do have a pic of the board.
This one. If the noise is still present, we can suppose the culprit is the tube or the JFET follower.
But IMO this design can be enhanced notoriously. Why use a JFET follower (high input impedance, desirable) and using only 1600ohm gate resistor (3300 paralleled)? (Less than a germanium transistor).
Hi. I removed the 10uf capacitor and the noise is still present. But obviously now doesn’t get louder with volume.
So what’s the next step get a replacement Nutube?
Many thanks.
