I did 18mm which I feel is a tad too big. Close inspection suggests 15mm is just about right.Hi zoom777. I have a similar case. I was thinking of doing holes for the RCA jacks just like you did. What size did you have to cut so there's clearance for the plug? Thanks.
The chassis only consists of screws to hold the chassis together, the power connector and rubber footers. No other items.Thank you very much for you kind help.
I will buy everything.
Unfortunately, I cannot find Belden retailer here.
Is there a cable that you can advise to buy at Aliexpress for the speakers?
And does the box came with the screws and mounting pieces to hold the board?
Thank you very much.In this thread, someone mentioned about 16ga cables from Ghent Audio with the proper connectors for the AC and speakers. Please look for it.
I tried to search this thread but couldn't find it.
I will look at Ghen Audio for speakers cables.
Maybe I can buy from them.
Thank you very much for your kind help!
So how did you put the board on the case?The chassis only consists of screws to hold the chassis together, the power connector and rubber footers. No other items.
Did you buy special connectors to hold the board?
PCB standoffsSo how did you put the board on the case?
Just to link some examples:
https://www.aliexpress.com/item/1005004243050141.html?spm=a2g0o.productlist.main.43.bef2265dnt8tgm&algo_pvid=5f0a844c-ab55-4f53-9691-eaf6b8a59180&algo_exp_id=5f0a844c-ab55-4f53-9691-eaf6b8a59180-21&pdp_ext_f={"sku_id":"12000028501025961"}&pdp_npi=2@dis!SGD!1.09!0.98!!!!!@2102196716740527329544991d06c2!12000028501025961!sea&curPageLogUid=6maj64PZdbDJ
I used 10mm versions so that the overall height is not too tall
Dear Zoom, I have no words to thank you!!PCB standoffs
I hope this module really sounds well.
I have a TPA 3255 that is too shallow and hope this one is good.
have you gotten the amp yet?So how did you put the board on the case?
Hi, what do you mean by 'too shallow'?Dear Zoom, I have no words to thank you!!
This is the M2, right?Dear Zoom, I have no words to thank you!!
Thanks!I did 18mm which I feel is a tad too big. Close inspection suggests 15mm is just about right.
Yes, we'll take 2weeks holiday.@ilan5555 I believe most sellers in Aliexpress, and even Eric is going to take a lonnnng break. Most sellers are shipping only from first week of Feb. FYI.
Wish all my friends good health and happy family in the Year of the Rabbit🙂
Thanks,Eric
Here's the Ghent speaker cables:
http://www.ghentaudio.com/item/jst/vhr4m-cable.html
Like something is missing. When I compared it to my Denafrips Thallo, it was like moody or something.Hi, what do you mean by 'too shallow'?
The Thallo is really an incredible amplifier
He already sent it. Is very quick!@ilan5555 I believe most sellers in Aliexpress, and even Eric is going to take a lonnnng break. Most sellers are shipping only from first week of Feb. FYI.
Thank you. It's only 30cm. I will see how to manage with the cables Eric sends and I will see. I'm not sure 30cm is enough.
Also, the box shipping cost is extremely expensive so I'm trying to search for alternatives.
- Vendor's Bazaar
- 2x150W Amp module for sale
