Hello my name is Jordi and i've been considering making a loudspeaker for my final project.
Is there any thread or article for helping me chose a certain speaker, with blueprints. I can only use 400-500 euros for the parts of the speaker.
Im planing on using CNC on using plywood or mdf like in the foto.
Thanx in advance
Thanx in advance
Is that a faceted surface?
There are lots and lots of designs with full drawings. There is a very rich vein to mine.
I personally am a big fan of FR loudspeakers.
Do not spend a lot of cash on your first build, you will learn much, and it will inform the choice of your next build.
The first driver i would suggest looking at is the Mark Audio CHN-110, you can build a very well rounded, well behaved loudspeaker.
Check out waxx’s comments on his ML-TL.
dave
dave
that is pretty.What speaker? My favourite are Karlsons.
I was thinking on a 3way, since i'd figured it would be more challenging, and i rly want to own ones.
Given it is a carpentry project, i expectthe woodwork is the most important.
Your budget is somewhat limited for a decent 3-way.
dave
dave
Yes it is, i want it to be wavy like the sound hehe
Yeah i've seen so many that i got overwhelmed, that's why i wrote that.
The other idea is to take the parts from my elac debut 6.2, and just make the box. It will be my last resource tho.
Thanx for the suggestion i'll look into it.
Well i just need the parts tho, i might be able to find the wood in my school, eitherway the wood it's not the most expensive part i think.Given it is a carpentry project, i expectthe woodwork is the most important.
dave
i was thinking on 400 for the parts since they will become my future speakers.
I've got a marantz 2250B so i want something that matchs it
Jordi
You want to worry about how that will affect the diffraction.
400 for parts for a 3-way is pretty skinny. Better to use fewer better parts.
dave
Do you get credit for the CNC complexity / uneven pattern if it is on the inside of the cabinet?
https://www.diyaudio.com/community/threads/ideal-speaker-shape-to-make-at-home.380342/#post-6872478
Or would you be able to cast clear resin over the complex design (so the surface of the clear resin is smooth and won't impact the sound)?
Would the outside dessing affect the sound?, I like the complex pattern on the inside too tho, i'll look into itDo you get credit for the CNC complexity / uneven pattern if it is on the inside of the cabinet?
Or would you be able to cast clear resin over the complex design (so the surface of the clear resin is smooth and won't impact the soundi
Yes the plan was to put varnish on the outside pattern.
Yeah, that is some of the idea that i have.Maybe contour a waveguide into the front panel.
thnx
Oh, ok. Then ill look for a FR with only one driver maybeYou want to worry about how that will affect the diffraction.
dave
Sound quality doesn't relate to the cost of the parts, it comes down to the choices you make.I've got a marantz 2250B so i want something that matchs it
Yeah i figured that cheap coherent set up would sound better than a nonsense expensive one.Sound quality doesn't relate to the cost of the parts, it comes down to the choices you make.
Still i have no idea on where to start since i got my firts speakers less than a year ago.
it was my grandpas so i had no choice on getting the amp.Sound quality doesn't relate to the cost of the parts, it comes down to the choices you make.
Just to be clear (ha!), I was talking about a thick coat like a bar top that would completely smooth out the pattern.Would the outside dessing affect the sound?, I like the complex pattern on the inside too tho, i'll look into it
- Member Areas
- Introductions
- Carpenter Exam
