Need help designing TL for 30cm woofer
Can you calculate a TL box for this woofer? Thanks in advance.
in the link below you can find 2 design options for a TL. I would also suggests to check the MLTL options too.
https://freeloudspeakerplan.rf.gd
If you don't know how to design, it's not a problem, just change the dimensions, export hornresp data and check the results. Everything is automated and focused on new users. Doing the loop twice, three, four times, you will start to understand how it works and people can help you to optimize the results.
You will need some woofer Thiele / Small parameter in order to run this process.
NEVER fails to deliver. Get it close to the 3 xFb freq in offset and stuff it a bit around the driver to avoid any hiccup
TLs output from both ends - so they are efficient in that sense. And so they can use smaller drivers and the whole cab becomes smaller. And being loud you have the freedom to stuff more stuffing into the pipe and the more stuffing the better the sound.
B.
B.
Too much stuffing and ….. neutered into something else.
not enuf stuffing and …. Lots of extra ‘noises’.
maybe?
