miniDSP SHD Studio and connect with AES/EBU.Hey,
I just bought a pair of FA123. And now I’m looking for a decent preamplifier to along with them. Is there any sort of preamps that don’t work well with the FA123? Are tubes and a no go for instance?
All the best
Mads
Or a miniDSP Flex Digital with S/PDIF for less money (and of course with less functions) than the SHD Studio. The Flex Digital even have analouge input as a plus.
The issue with tube preamps is that they often have a rather high output impedance. On the other hand, why would you want a really transparent and accurate power amp, and then color/distort the sound with tubes?Are tubes and a no go for instance?
If someone likes "tube sound", isn't it better applied with a preamp than with poweramp? With NCore poweramp you can still enjoy proper bass response.The issue with tube preamps is that they often have a rather high output impedance. On the other hand, why would you want a really transparent and accurate power amp, and then color/distort the sound with tubes?
^ Just for fun or as an option?
Even many latest DAC chips have tube and transistor emulation! VST plugin with Foobar etc. are old tricks
https://www.diyaudio.com/community/threads/how-to-add-tube-sound-to-a-system.369011/
Topping D90LE https://www.audiophonics.fr/en/dac-...038pro-32bit-768khz-dsd512-black-p-16489.html
Yes, I was going to add "if one isn't comfortable with using DSP for it" as is quite often the case 🙂^ Just for fun or as an option?
True.If someone likes "tube sound", isn't it better applied with a preamp than with poweramp? With NCore poweramp you can still enjoy proper bass response.
The problem with these emulations is that they are linear, unlike real tube distortion, which gets higher with higher signal and behave differently at overdrive/clipping. So, IMO and experience, they don't sound like real tube (pre)amps.
My option is Prologue 3 https://www.stereophile.com/tubepoweramps/1206luna/index.html
The non-linearity is probably the easiest part to simulate/emulate.The problem with these emulations is that they are linear, unlike real tube distortion, which gets higher with higher signal and behave differently at overdrive/clipping. So, IMO and experience, they don't sound like real tube (pre)amps.
The most transparent and lifelike amps I've listened to have all had tubes somewhere in the signal path.The issue with tube preamps is that they often have a rather high output impedance. On the other hand, why would you want a really transparent and accurate power amp, and then color/distort the sound with tubes?
Thanks for all the answers.
If I went with a purely digital solution, would a streamer into the Hypex FA123 and then the Hypex Remote Kit be enough? Invariably, I've always found that a system with a preamp sounds better than for instance DAC-direct with a digital volume control.
Anyone heard/used the Hypex Remote as their everyday volume up-down?
I have a ZenMini MKIII with the LPSU. Maybe just plug that in as a Roon Core and control volume from the Hypex Remote? I guess, when the signal gets digitized in the Hypex DSP crossover anyway it might make sense....
I have two pairs with FA123, one gets analog signal from Yamaha WXC-50, the other analog from Cambridge AVR. Digi signal is only used when doing xo development and testing.
Your subjective perception is noted, but by all objective criteria, only the best tube amps come anywhere near the accuracy and transparency (as in "output signal as close to an amplifies copy of the input signal as possible") of modern solid state amps.The most transparent and lifelike amps I've listened to have all had tubes somewhere in the signal path.
If for some reason you don't get the tube sound you are seeking, try adding series resistors after the power amp, about double of the Re of your drivers. I have a hunch that could have an effect for better.Well, you did ask me why I wanted to put tubes in front of DSP😉
Indeed. That will produce an uneven frequency response in the same way as the output transformer of a typical tube amp.If for some reason you don't get the tube sound you are seeking, try adding series resistors after the power amp, about double of the Re of your drivers. I have a hunch that could have an effect for better.
Why do you use a digital signal for XO development?I have two pairs with FA123, one gets analog signal from Yamaha WXC-50, the other analog from Cambridge AVR. Digi signal is only used when doing xo development and testing.
Yes, no problems in that.Thanks for all the answers.
- the argument about bit / resolution loss starts when you do the volume regulation on the source (streamer) but even that might not really be an issue in real life applications w. proper bit rates.
For the FA's, and with longer digital cable runs I have noted issues with SPDIF. 192k/24bit can get lost in the chain, usually after the first two units.
The RCA's used are really an inappropriate solution for achieving proper impedance matching on the high speed SPDIF interface - they should have used BNC. I tried canare/bomar-win crimped RCA's and it still does not work well.
The balanced AES/EBU digital interface works without issues. SPDIF is then used only between the FA amps (4x in my setup) for sync between the units (volume, preset and stand-by).
For analogue vs digital etc. I recommend to try out the oversampling filter settings in either your source (e.g. streamer) or the FA's. It is not only measureable. this might have bigger impact than A vs D.
I hoped it would be a negligible difference when changing this on an Aries G1, it wasn't.
- Class D
- The New Hypex Fusion Plate amps
