Zapco 6.5k monoblock
anyone ever repair this model? no power but the relays clicks on ..and there is rail voltage present...no sound and the power led is not lighting on..
Do the relays disengage IMMEDIATELY when remote voltage is removed?
Is there a short delay after applying remote voltage before the relays engage?
Do you see the input signal reaching the audio driver board?
Is there any modulation of the rail-rail oscillation at the output transistors when you drive a signal into the amp?
