High-impedance speaker with LM386-based amplifier (550 ohms...)
Hi - I have an amp that I made based on the "little gem" amplifier circuit (LM386-based). I want to try to run it through a speaker from an old AM radio, which is a reed-type speaker supposedly with an impedance of 550 ohms (though I might be misunderstanding the schematic). Is there any way to do this while getting a reasonable amount of volume out of the amp/speaker?
Thanks in advance for your help.
Little Gem Schematic: littlegem.html
Interesting... and I might be way off the mark here but if the AM radio was a mains powered unit then the 'Reed' type speaker may be such high impedance because it is intended to be used without a matching transformer. In other words it could run off what would be a high impedance point like the anode of an output valve.
If so then I'm thinking that the high impedance means you will not get much useful volume from it on a low voltage amp such as the LM386.
Have you tried it just for fun?
I haven't tried it yet, because I'm still waiting on a few parts for the amp (ran out of capacitors). Here's a picture of the speaker, still in the radio. The schematic for the radio is here:
a reed-type speaker
The point of G.E.'s reed speakers was that they were VERY efficient and would make decent sound on very small amplifiers.
I am sure you will get "some" sound. Enough to hear across the room.
FWIW: I have a reed in my ear. So do many stage musicians. The balanced armature (reed) earpiece is used in all good hearing-aids and most in-ear monitors. Yes, it has severe limitations compared to voice-coil drivers but within limits makes 5X to 10X the sound power per electrical milliwatt. OTOH it is fussy about alignment and may not have aged well.
https://www.knowles.com/subdepartment/dpt-ba-receivers/subdpt-hearing-instruments-receivers
https://www.knowles.com/subdepartme...sound-balanced-armature-receiver-and-speakers
https://knowles-cms.ae-admin.com/do...ry/wp03_science_of_premium_sound.pdf?sfvrsn=0
Reactions: NanoFarad
