Best cheap (under $50) driver to cover everything above ~500-800Hz?
Looking for the "full range" driver in a 2 way OB setup. Bass driver is a GW-212/4 which I will XO around 700Hz or so max. Not sure which way to go. I don't need a ton of power so that opens things up. Would prefer decent efficiency if possible. I've seen a lot of weirdness around ~3-4" full range woofers and even some coaxials.... kind of thinking about this Hi-Vi DMB-A full range soft dome:
https://hificompass.com/en/speakers/measurements/hi-vi-research/hi-vi-dmb
HF extension is just OK but I mainly listen to old music anyway (plus my amps have DSP). I have no idea if this is actually good though. Just looking for some ideas.
I would not run that HiVi that low. Its Fs is 700 Hz, and you typically want to stay above that by a decent margin. Xmax on large domes tends to be a bit puny also. If you're interested in an open baffle, it seems like an odd choice since it has a sealed cup.
Peerless TG9FD10-04 is a pretty good option for a low cost, wide bandwidth, low power situation.
https://www.madisoundspeakerstore.com/approx-3-fullrange/vifa-tg9fd10-04-3.5-full-range/
The HiVi 2" domes are 850Hz+ at best, usually nuking the Fs in the process.
If you are looking 3-4" size, and want the sensitivity, then the Dynavox whizzered full ranges apply, Faital Pro and Lavoce apply, and so does PRV.
I recommend the PRV 4MR60-4 4" midbass. I've used it, and it sounds great from 100-4k sealed in 2 ltrs.
As long as you remove the xmax from the equation, then you are likely good open baffle from 500Hz+.
