Help needed for a Bass reflex cab for PD.24603BR 24" driver
There's a new lady in the house.....
Careful, she's a bit shy...
Any suggestion for cabinet vol and port length / width would be hugely appreciated.
Parameters as follows:
Nominal Diameter24” / 610 mm
Voice Coil Diameter6.08” / 152 mm
Power Rating 1 2 *1800 W (A.E.S.)
Available Impedance8 Ohm
Sensitivity (1W/ 1m)*98 dB
Frequency Range20 Hz - 200 Hz
Peak Power (6 dB Crest Factor)7200 W (A.E.S.)
Resonance34 Hz
Voice Coil Winding Depth37.00 mm / 1.46”
Recommended Enclosure Volume150 - 220 Litres
Flux Density1.5 Tesla
Magnet MaterialNeodymium
Magnet Gap Depth15.0 mm / 0.59”
Former MaterialGlass Fibre
Dust Dome MaterialSolid Paper
Voice Coil MaterialCopper
Cone MaterialPaper
Suspension MaterialFabric
Surround MaterialFabric
Fs34 Hz
Re5.3 Ω
Qms9.92
Qes0.32
Qts0.31
Le (@ 1 kHz)4.01 mH
Le (@10 kHz)1.51 mH
Vas355 Litres
Mms440 g
Sd2239 cm2
Cms49.8 μm/N
BL39.46 T/m
Xmax16.00 mm
Vd3.58 Litres
Ref. Efficiency4.19 %
EBP106.25 Hz
Vintage spec driver, so many of the pioneer's cabs will work or with a modern max flat ~149 L net/44 Hz tuning, though the pioneer's ~247 L net/actual Fs acoustically optimal BR would be my choice.
Anyway, its specs allows many alignments, so maybe best to tell us any size, room placement constraints, preferred type(s) musical/whatever playback at average SPL, etc..
Reactions: horn_power
What? Vintage, are you having a laugh?
Of course, everyone here knows that vintage drivers had power handling of 1.8Kw, 98dB sensitivity and a BL force factor in excess of 39. Clearly i have stepped into clown college here? Forget it, I'll go elsewhere for a more sensible response. Nice going!?
Good bye.
Mods
Please feel free to remove this thread.
Rich
Reactions: MrKlinky
Rich,
An Fb of 15Hz or one of 34Hz (or higher) will suggest quite different cabinet volumes, port lengths / areas.
There will be trade offs between port velocity, drive level, Fb, and port resonance that are all length and area dependent. The alignments are literally endless.
It has been 14 years since you said you'd buy a P.D.24, have your ideas changed since that era?
Art
Rich, ran the T/S parameters & I got this...the EBP at a very high value points toward a vented alignment. The standard values thru the simulation came out kinda lame, so upon "tweaking" I got this monster to perform better.
An internal volume of 310 liters, tuned frequency of 41 hertz...and we get a best performance of -3.03 Db at 38.35 hertz. Port came in at 300mm high, by 400mm wide, slight rectangular, 422mm long inside.
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Rick...
Using the common enclosure ratio of 0.618/1/ 1.618 ...this gets you an internal dimensions of 676mm Wide, 417mm Deep, and 1093mm Tall. The 24 inch driver is almost the full width of this enclosure, the port volume is such that the big driver needs to be near the top. Grab a piece of paper & a ruler & start drawing out the dimensions...compensate for the volume of the port as to make the enclosure slightly larger.
Good bye.
Mods
Rich
No, serious as a heart attack, just apparently a lot more educated/experienced on the subject than you, i.e. its T/S theory specs that govern box design are very close to the '40s - '60s era Altec, EV, etc., drivers I used and still used for some prosound apps, so lots of options or can design one to suit the needs of YOUR app if you tell us what it is.
Good bye.
Mods
Rich
Are you on your period?
And honestly over here is more relaxed than the other popular audio gathering place where they lock a thread cause you do not say something that the moderator like.or they ban people cause they don't endorse the brands they like.
It would seem that "Rich" here didn't want to bother with doing the work by himself, AKA "Do it Yourself", DIY...Frankly these giant drivers do the "tub thumping" thing, a one note driver, kinda useless. I'm guessing those thirty-inch Electrovoice drivers of long ago were similar & had a very narrow role in making music. Sorry, thirty eight hertz down three Db ain't much to write home about.
Have you tested this driver yourself?
No need to "listen for yourself"...assuming the TS parameters are relatively accurate...I know what 100 hertz, fifty hertz, thirty hertz sounds like...and the response falling away at only 38 hertz is NOT a "great" performance for a woofer, mediocre at best.
Reactions: JRKO and GM
Yes? No?
"...how a driver sounds" is a subjective term. How deep in frequency is what we are trying to achieve...how low in hertz...when it stops performing and at how much decibels it falls away.
Now, just how these low frequencies propagate thru any one listening space...well, that's a whole nother' issue...room acoustics.
How can I say response drops off after 38 hertz?...it's right there on the graph!!! Eighteen inch drivers seems about the limit, even with ultra-light materials, past that the square-cubed law starts to interfere here, cone control getting harder & harder.
Reactions: GM
Which graph are you referring to? The 975L CB one on the specsheet? Or a simulated response?
Both don't tell much imho and only points you in a direction. Its older brother the PDN2150 has been used in multiple environments including larger PA's and none describe it as uncontrolled. The 246003 is a noticeable improvement over the 2150 in lineair excursion and control.
In the future I am possibly in the situation to post some measurements of the said drivers.
I would have thought most all of us here have one or more simulation programs, so one can model a drivers performance...my bad, sorry. One of the first simulations commonly available is "WinISD", the beta version...it's freely available , one just plugs in the TS parameters & the program gives you a sealed, ported, 4th order and sixth order bandpass enclosures. It calculates optimum sizes(volumes), for ported enclosures, box volumes, tuning frequencies along with port sizes, shapes....all of this graphed out for you. With experimentation you can really turn a turd of a driver into its best possible...Additionally you can see starkly some really unsuitable & performing drivers...no matter how one tweaks things, some are truly bad..& you can see it right there on the graphing....despite some silly fawning over one particular driver, the graphed out performance is right there to see & shake your head & roll your eyes....facts vs. "impressions"...or myths, take you pick. Load it up & try it for yourself, it can be quite revealing...."so that's why this sounds like it does?".
Reactions: JRKO and sonomanie
Oh, I am well aware of WinISD, Hornresp, Bass box professional , Akabak etc. You can simulate anything you want, if you do not verifie the things you simulate vs real world testing, the model is not very usefull. For me personally, simulation software like winsisd and (mostly) hornresp are only there to point me in some direction. Eventually the real world testing will give you what you want, and I take that anytime over some response plots in winISD. Hell even real "impressions" would be placed above a winISD response plot.
If that's not your thing, lets agree to disagree
Reactions: maxolini
