Single tube, Single ended, 20W, impossible?
Just use a dozen 12HL7 in parallel (were on the $1 list once) to get 120 Watt Pdiss, 252000 gm, 150 Ohm Rp in triode. Single stage, modest B+. Super triode curves too.
Yup, excellent triode curves for 4P1L. Just need a bunch in parallel. pics 1 & 2
Could also go for a new series Schade N Fdbk on a big beam pentode, like a 36LW6. Pics 3 is using 21HB5A as a similar sample. Looks like a DHT 211 I think.
Im sure there is some bazillion watt triode with a bazillion gain out there that you could run at 20 watts, but you would become your power companies new best friend.
If you take a closer look at it, there are not too many toobs to choose from. As to power, it depends where you liv. For instance, i need at least 15ooo kWh just to keep my house at 18°C during the winter, and amp dissipation would not change one yota on my bill. During summer i want sand, preferable between my toes, on a beach
My just for fun contribution.
https://frank.pocnet.net/sheets/111/8/845.pdf
.SUBCKT 845 A G K
+PARAMS: MU=5.355 ERP=1.5
  • KK1=6323 KP=85.64 KVB=65.8 vg0=3 va0=0
  • CGA=13.5E-12 CGK=6E-12 CAK=6.5E-12 RGI=4000;
.func V_6() {KP*( (1/MU)+((V(G,K)-vg0)/sqrt(V(A,K)**2+KVB**2)) )}
E8 8 0 VALUE={(V(A,K)-va0)/KP*LN(1+EXP(V_6()))}
Eam am 0 VALUE= {2*Pow(V(8),ERP)/KK1}
GA A K VALUE={V(am)}
D3 5 k DX ; FOR GRID CURRENT
R1 g 5 {RGI} ; FOR GRID CURRENT
Rak A K 1G
Rgk G K 1G
C1 G K {CGK}
C2 G A {CGA}
C3 A K {CAK}
.MODEL DX D(IS=1N RS=1)
.ENDS
Finding a 150:100k audio step up transformer capably swinging 134 volts p-p: consider switching to bourbon.
That is not actually the harder part if there is no DC current in it. It's a reverse 26:1 transformer where you can use mumetal, for example, that has got permeability 10+ times better than GO laminations. Enough turns to deal with the voltage and a good winding geometry. The harder part is driving the 845 through such SUT trnaformer...35-40 nF at least up to 20KHz..
I guess the guy who built that power amp with the 211 was driving it with a preamp using the same transformer in reverse mode: 100K:150R.
Only practical side of this is that you can put them in separate cases....
Otherwise it looks more like a tube amp that needs a strong SS preamp. Maybe even using some specilized OP-amp...
