Opinions experience and recommendations to help me choose between MAOP-7 & MAOP-11
My experience, if of use to anyone -- probably not! I started with a MAOP7 in a FH3 and found the bass too room bloomy. Moved them out of the corners, back into the corners, tried a lot but could never find a sweet spot. Changed to 7l closed with an eq'd 12" pro driver in ~30l WAW. Prefer it 10 to 1 over the single driver. I've not listened to the MAOP10, but have also lived with the Alpair10.3 in a couple of configurations and the MAOP7 subjectively wins for me hands down.
No, the more cosmetically appropriate ones with sealed SDX7.
The M7 i have did spend a condiderable amount of time in the MTMs you mention.
dave
Right, so I’ve kicked off a Storm Shadow build, for the MAOP 7.2s. Have cut up a small sheet of 12mm Red Oak ply, and will be using some spare 18mm for the baffles (sides adjusted to suit). Only have 4 short clamps, so the glue up will be slow. Don’t have any 1/2 inch felt either, but do have some poly acoustic insulation, that I can cut down to the required thickness - do the experts see any flaws in this approach?
Here’s a few pics of progress so far. Getting the cut outs sorted with a diy circle gauge was the most nail biting part so far, but more than happy with the results.
BB
Reactions: infected
Hi nandappe, I have purchased some maops with your recommendation - you look like you know what you're talking about with advice about different maops. I was looking at different cabinets and saw your post on some you have. Are the plans available? I have done some searching here's and google and can't find them. Thanks you.
Cabinet for MAOP10 - Stagger Damp-Duct Back-loaded Horn Enclosure
Hi Matt81,
URL for various plans.
https://sites.google.com/view/low-end-diy-loudspeaker/home
https://sites.google.com/view/low-e...iver/-diy-adjustable-duct-type-sddbh-sddbh-ad
  • Thank You
Reactions: mp9
Damped Duct is better decribed as an ML-Voigt (a back loaded horn variation)
Hi Dave,
Based on the impedance characteristics, I believe it would be appropriate to refer to it as a "back-loaded horn."
In my listening experience, I mostly perceive it as a Back-Loaded Horn.
What are your thoughts on this?
