If the scope is isolated from the main supply, ground the scope probe ground clip to the source leg of the FET and recheck the signal.
Do you have a 0.01uf film or ceramic capacitor?
You need to ground the scope probe to the source pad of the FETs? << Only if the scope is isolated from the mains.
Thank you, I already managed to get the diodes and the 3120 I have again the signals in the high and low side gate with a 0.1uf capacitor, in the end it was the resistance of r287 and the one of 100 ohms that is below d252, d260 and d253 and a 1000uf capacitor at 35v.If it actually opened, the optocoupler that it was regulating for, may have failed.
MMSZ5250
Confirm that size is right before ordering.
Maybe from here I got confused, could you enlighten me how to make this connection?If the scope is isolated from the main supply, ground the scope probe ground clip to the source leg of the FET and recheck the signal.
YesWere the scope tip and ground connected directly across the capacitor for these waveforms?
I see the problem. The only signal is the 45Hz input. Do you have a signal generator that you could use to inject a square wave of at least 20kHz?
I'm sorry, my device doesn't do that functionVeo el problema. La única señal es la entrada de 45Hz. ¿Tiene un generador de señal que podría usar para inyectar una onda cuadrada de al menos 20 kHz?
- General Interest
- Car Audio
- MTX 81000D LED 238 does not turn on and no audio
