Hi, where did you find the ISO FC-40-5s opt at a ~69k yen/opt price - the lowest I found was 77,400 yen/opt on the ISO site (https://isotransformers.tokyo/カタログ/) and $665/opt on the http://www.tubesusa.com/ISO-SEoutput.html site. Thanks.Hi Victor, iso-tango FC-40-5S is ~ 69000 yen each. Hashimoto H-30-5S is 61000 yen. About the same price…?
Hi Victor,
Can the Lundahl OPT LL1688 (specs: https://www.lundahltransformers.com/wp-content/uploads/datasheets/1688.pdf) be used instead of the stock OPTs on the SunValley SV-S1628D - the 211/845 amp?. It is listed as 5.5 kohm and 'designed for 845 tube'. I use Lundahl OPTs in my elekits purchased from Victor (and love them) and these Lundahls are less expensive than the Hashimoto and ISO variants listed above.
Thanks in advance,
Rob
Thanks in advance,
Rob
AS I said FC40.5 is double the price. You need to consider the shipping from Japan too.
I am asking Sunvalley to source for me. The price should be lower.
At the current low JPY, I will consider the Hashimoto and ISO. FOR Lundahl I need to make a PCB to confiigurate the output. Also Lundahl do not offer 16 ohm impedance.
Please stay tuned the pricing of the upgraded opt from Japan.
That's great news..... Fingers crossed to hear moreAS I said FC40.5 is double the price. You need to consider the shipping from Japan too.
As long as the low JPY, I will shift all upgrade opt to Hashimoto or ISO.
THe New 45 tube amp from Elekit includes Hashimoto PT/Chokes X 2 / OPT. Basically the low JPY to make it possible at affoable price range.
Hi Victor, this maybe too expensive but any possibility of identifying suitable Tamura opts for those of us DIYers who might like to give the Tamuras a try?As long as the low JPY, I will shift all upgrade opt to Hashimoto or ISO.
In fact, I can order large quantities to lower the price...
This time I want to make this 45 tube amp good and afforable..
Mr Ohashi comfirmed with me. H30.5 is sufficient for 211/845 amp
For amplifiers with transformer-driven circuits and outputs of 30W or more, the H40-10S would be the preferred choice
So we will offer H30.5.. I only have 4 pairs . The price is JPY 56,000 x 2 plus shipping
I will be interested in SV1628 with Hashimoto when it is available. What is approximate replacement cost of the 845 tubes you recommend?
Just approximate cost of replacement tubes, that’s what I’m asking. I need to know if this amp is expensive to service, like a 300b amps?
Still v interested in getting a pair of H30.5 let me know the total cost as soon as you knowthe cost is subjct to the shipping fom Japan.. I should have the amount early next year
Nick
Generally speaking a pair of regular 845 or 211s will costs ~ 350+ including shipping. Decent ones will cost 450++ a pair not including shipping. The days of cheap 845s are long gone.Just approximate cost of replacement tubes, that’s what I’m asking. I need to know if this amp is expensive to service, like a 300b amps?
Normal linlai 300Bs are ~ 300 a pair. The comparable 845 or 211 of similar quality will be roughly 15 to 20% more. The NOS 845 or mil-spec 211s are mostly collector prices ie multiple $k. and best to buy from sellers who have 1000+V curve tracing equipment. Nice modern 845s are around 800 to 2000 a pairAt least that’s still half of what 300B cost
There's a new 45 kit coming out?! ? I can't see it on the Elekit site. When is it due to be released?As long as the low JPY, I will shift all upgrade opt to Hashimoto or ISO.
