Freshen up pair of AKAI SW-130 Loudspeakers
Those caps were not from Jaycar; much higher quality than the cheap ones from Jaycar.
BTW you can't really go wrong with adding a little polyester filling, or even fibreglass in a sealed box.
Even better. Thanks Ted.
I'll be fitting the caps in the Rotels as well.
Just working on routing the woofer holes 6mm.
A spanner in the works.
I thought these boxes were sealed, until I noticed a slot cut out of the baffle board about 25mm x 120mm when reassembling.
So the speaker lead plug holes aren't the only area of leakage.
I can see three options.
1. Leave as is but plug the input jacks.
2. Also fit a port tube.
3. Plug all holes, stuff the boxes with wadding & treat as sealed.
Don't know which way to go?
Some info:
The narrow 120mm x 25mm 'vent' takes the place of a 'circular opening fitted with a tube' (which is what we typically call a 'port').
Some early speakers employed a narrow vent in place of a port to avoid the need for 'sharp' port tuning, making it simpler to employ and more flexible in application.
P.S. Not to be confused with a 'resistive vent' which would be covered by soft cloth or filled with fibreglass.
Some info:
The boxes are lined with a thin layer (2") of fibreglass sheets (sides, top, bottom, & rear).
Glad you're happy with the outcome, Cliff.
I trust you've sealed up those input jack sockets so they don't leak air - as planet10 remarked on earlier.
The jack points are sealed with emastic.
I've supplemented the fibreglass lining with 1" thick foam lining (incremental improvement).
I've removed the parallel caps reducing capacitance from 4μF to 2μF for each Tweeter, and soldered back in place.
The remaining caps were fixed with emastic to eliminate movement or vibration.
Initial revue.
Not audiophile grade but pleasing to the ear.
Nothing harsh or distracting.
Will spend more time listening to them as well as trying different Amps.
