Self splitting push-pull idea
What if we create a local feedback around one of output tubes similar to a paraphase splitter? I have no illusion that I'm the first but I couldn't find any mentions of this circuit. Does it have any major flaws except it will work in class A only?
Not really a new idea, here is something from WW2.
I tried several variations of the concept early 2017. All the results are here somewhere on DIY.
The resulting report with many measurements is here in a pdf.
Best results were got using a choke as the cathode impedance.👍
Without using any semiconductors, and without using any vacuum tubes, how do you make:
A constant current sink?
A constant current source?
Have you forgotten?
A choke often makes a good current sink or a good current source.
"You should make things as simple as possible, but no simpler" - Albert Einstein
In the schematic attached, I would add a choke or resistance across both screens tied toghether and Ebb, and capactivelly decopled to cathode (floating for audio signal) so the the action may be enhanced (common cathode & screen coupling).
wg_ski,
I have used chokes as CCS.
The bandwidth covers 20Hz to 20kHz.
Unless you are listening to Telarc's definitive recording of the 1812 Overture, which has 6Hz real canon signals, I would not worry about needing lower than 20Hz bandwidth.
How many of us have speakers that go down to 20Hz cleanly (at a high enough sound level that our ear's Fletcher Munson Curves do not prevent us from hearing the 20Hz sound).
Much of what we will hear from most speakers that try to reproduce 20Hz at any moderate level, not even loud, is the 2nd harmonic distortion at 40Hz, and 3rd harmonic distortion at 60Hz.
Let's check which layers of the Onion that we are peeling off first.
Just my opinions.
