No sound from one of the Rotel RL 870 Speakers?
Hi All.
Hoping for some help.
I have a pair of Rotel RL 870 Speakers.
When I first set them up for a listen, there was no sound out of one of the enclosures.
The only way in was via the woofer hole on the baffle.
As well as the fixing screws the woofer appeared glued on. I couldn't budge it so this project sat around for 6 months.
I recently re focused and was able to budge the woofer from the baffle with a piece of timber and a mallet.
I carefully tapped the woofer around its circumference, and without damage was able to break the grip of the glue.
I tested both the woofer and tweeter with the battery (1.5v) method on the terminals.
Both drivers are alive and moved outward when +ve terminal aligned with +ve battery.
A careful look at the crossover and solder points hasn't revealed any obvious broken joints in the wiring.
Any thoughts for further tests?
Also the thick internal cabling is marked "SUPRA".
Should I replace this with the CAT5 solid core wiring while I'm at it?
Also the capacitor might need to be replaced?
Have you measured the resistance from the outside? Short the terminals temporarily then measure and it should respond to the woofer resistance plus the inductor resistance.
Have you confirmed the amplifier is OK?
Ohms, yes. You said the woofer is OK. Connect it back up and measure the whole speaker. This will check the woofer coil and connections as well.
Don't measure with the terminals shorted... that's just to ensure the capacitors aren't charged.
Reactions: GM
Is that slightly higher than the woofer resistance?
Try using the 1.5V on the enclosure terminals.
Sorry Allen.
I'm all over the place today.
Revised feedback.
Good speaker:
1.5v test on woofer terminals = healthy pop and movement.
7.2Ω from enclosure terminals.
Speaker with inoperative Woofer:
1.5v test on woofer terminals = small pop and little movement.
1.2Ω from enclosure terminals.
I'm inclined to think no, but at this point unless you can find an obvious external cause then I'd suggest you don't have much to lose.
It's a shame.
These are well proportioned late 70's speakers with genuine walnut veneer and well proportioned bookshelf cabinets with quality drivers (scanspeak tweeters).
The crossovers may appear prototypes, but apart from the iron core inductors, sand cast resistors, & electrolytic caps, the layout has plenty of room to work and allows for anchoring of the leads.
I'd say original woofers will be either expensive or difficult to find.
Maybe my only alternative is to replace them with modern woofers of similar size and output??
I can't find any information on these speakers, Cliff, other than they were made for Rotel in Denmark in the 1970s and sport a 20mm Scanspeak D2008 tweeter and an 8" treated paper cone bass mid sourced from an unknown UK manufacturer.
I suspect the RL 870 enclosure is sealed like that of the 'Made in England' RL 850 attached, in which case it may be posssible to find a suitable replacement 8" driver that will at least get you up and running.
