Stetsom oscillations duty cycle
Hi all
Stetsom with 2 irs2092 Ic. Two channel input with one speaker terminal output.
One ic has 42% duty cycle and the other has 47% duty cycle. Will that make any problem for the amp to go into protect after playing a minute or less?
The high pass has two different value pots is that correct? Will that be the problem?
If you monitor the offset across the speaker terminals from the time the amp powers up (output goes to about 75v (referenced to ground), does the offset increase just before the amp goes into protect?
Using the primary ground as the reference, is the DC voltage on pins 1-6 of the two driver ICs essentially identical?
If not, which pins are different?
Voltages on Pins 1 and pin 6 are very identical.
What i notice is Amp only goes into protect when the flat switch is off. When the flat switch is off gain is very sensitive as I turn very very little amp goes into clip and then protect. I still have 3.2v across speaker terminals. Speaker offset is 45v on one terminal and other terminal has 49v referenced to primary ground.
