Hi Sami, would it be possible for you to make a smps that can supply a full 63v to the hdplex 800w dc-atx? Perhaps a unit with 2x S440-TK4 modules?
SMPS440-TK4 can be configured to supply 63V as long as its a single rail output.
And no need to use 2 X SMPS440-TK4 to get 63V.
wonderful, how would I order a complete setup?SMPS440-TK4 can be configured to supply 63V as long as its a single rail output.
Hey Sami, what's the difference between the COBRA-S2R2 and the COBRA-S2?COBRA-S2R2 1400W output power with unmatched performance.
Rock-solid output voltage with any input voltage range 120VAC ~ 265VAC
Both units are identical, with a capability of 1500W.Hey Sami, what's the difference between the COBRA-S2R2 and the COBRA-S2?
But, COBRA-S2 has two DC outputs to drive two amplifiers, and two AUX connectors especially for Purifi amplifiers in stereo build.
Each amplifier has its own power cable to ease the wiring.
Any potential concerns for cross-talk using the same V+/V- rails for both channels?Each amplifier has its own power cable to ease wiring.
No problems ever reported when feeding two channels from the same rails.Any potential concerns for cross-talk using the same V+/V- rails for both channels?
For wolverine amplifier, what would be the most optimal smps? For example, I am considering as an alternative a linear power supply with 500 VA transformer into 59V (55 V for smps).
The best option for the Wolverine amplifier is the COBRA-S2 for stereo setup.For wolverine amplifier, what would be the most optimal smps? For example, I am considering as an alternative a linear power supply with 500 VA transformer into 59V (55 V for smps).
Noted. Looks like your smps will make my assembly much easier. Just need to save some cash first. Is sparkos upgrade has a significant difference on sq?
The Sparkos regulators made improvements in many Purifi amplifier builds.Noted. Looks like your smps will make my assembly much easier. Just need to save some cash first. Is sparkos upgrade has a significant difference on sq?
I am not sure if I have stock, let me know what voltage you are targeting
Take your time, once you decide what you want to order PM me for your discount code.
Apologies if off topic. I would like to use 12 v trigger input, what do I need to add to my preamp to make it work?
- Vendor's Bazaar
- Audio SMPS units for sale
