Holywood RHV1200D cd4013b issue
Amp is pretty much the same as Fusion-FP9001D. Schematics are in Perry's guide.
Some guy tried to fix it, but made more damage to the amp than anything good. Output section was totally dead.
I've changed so far:
Hip4080 -->new one from reputable source
CA3290 --> NE5532
CD4069UBM --> new one from reputable source
CA5470 --> TLC2274ACN
Couple of resistors and caps. Took out the mosfets (they were indeed shorted).
I could NOT change the CD4013B as it's unavailable in my region anywhere due to supply issues.
Amp now starts but the FLIP FLOP CD4013B shuts down the hip4080 thru pin 3 going high. I do have all the +12v, +6v from the regulator.
When driven to clipping at the RCA input I see a small square wave modulated at pin 7 of the HIP4080 riding the 6v DC.
Pin 5 has 105khz square wave.
Pin 6 has the triangle wave.
Pin 1 and 2 have their 12v.
Only issue is pin 3 have 12.5v on it too, so the ic stays disabled.
Overload led stays on all the time.
Could not find any resistor out of tolerance, bad diode, or shorted transistor. I still can't wrap my head around the Truth table for CD4013B.
If it is helpful i can post voltages of any chip.
I kind-a hate this amp layout as everything is on vertical driver boards.
If you leave terminal 3 of the 4080 out of the socket and connect the lifted terminal 3 to pin 4 (ground), does the IC produce output to the FETs?
the are square waves at the output at 105khz, shouldn't they be at 100hz the frequency i'm injecting into the rca's ?
I know from your guide i can use 10k resistor and a film cap to inject a signal directly into the hip 4080 but the issue i feel is in the pwm/comparator board ?
With disabled protection as Perry suggested, across the terminals there is a square wave with the frequency injected thru the RCA, riding along some DC.
I've tried with brand new hip4080, same.
Tried with different mosfets and check those once again to be sure - not the issue.
I've traced the square wave from pin TLC2274ACN pin 1 (output). Going thru some resistors and it disappears when it reaches the mute JFET J112. I'm also missing 6v at TLC2274ACN pins 8,9,10.
NE5532P
1 - 11.5V
2 - 6.4V
3 - 7V
4 - 0V
5 - 0V
6 - 0.6V
7 - 12V
8 - 12V
TLC2274
1-0.8V
2-6.3V
3-6.1V
4-12V
5- 6.8V
6-6.8V
7-6.5V
8-0V
9-0.5V
10-0V
11-0V
12-6.1V
13-6.1V
14-6.1V
I have re-checked double, triple checked.
Even with no bridge at terminals 1 and 2 of the 2274 there are 6v DC at pin 7 at the hip4080.
When amp is starting up or during the start up, there are 9v at pin 1 at the 2274, but in a 1-2 seconds afterwards, it quickly drops to below 1v.
pin 7 at the hip4080 stays 6v all the time,
Amp is not 100% same as the fusion, but almost the same. I don't see a mute JFET J112 in the fusion amp, but I have one in mine. I guess there could be something more which differs.
