Crossover Help - Dyn Heritage Special
Hey guys I was wondering if someone could draw up this crossover for me - much appreciated! I would like to do some mods to the crossover to tame the tweeter a bit.
Thanks in advance.
The series capacitor at the negative terminal isn't so unusual but when combined with the inductor to that terminal, it's 'creative'. It simulates fine and I'd recommend starting there.
If it were me, I'd probably develop a second circuit to do precisely the same filtering with a more 'open to tweaking' topology. I can give suggestions if you like, and have a simulator ready.
Bit of a nightmare to untangle this Dynaudio Heritage Special, but I think we are just about there, thanks to AllenB and tuantran's work.
The bass section is 1.4mH series bafflestep and rolloff, and 4.7R and 4.7uF shunt which is just impedance correction really. Seems to be a 4 ohm woofer.
The tweeter section is some R1 resistor called a Mundorf MResist Supreme followed by a 3.9uF which is the first order rolloff.
This being a Dynaudio "First Order" crossover with the usual Esotec or Esotar tweeter, we now have a ladder or phase network of 2 coils and 2 capacitors. 0.5mH and 6.8uF values. Time delay really.
Zaph has done this sort of thing in the ZD5:
http://www.zaphaudio.com/ZD5.html
Finally, it looks like the tweeter is shunted with a R3 22R and a R2/C4 Zobel, which might be 6.8R and 1.5uF.
A couple of other similar Dynaudio circuits,
I have simulated these things, and they turn out a bit like the more regular Butterworth 3 with the tweeter polarity flipped.
I would guess increasing R1 will take the tweeter level down. I can't remember resistor colour codes, so maybe you can just measure R2.
Reactions: AllenB
Ya please do - I love the box and the drivers but the setup of the cross over is “too special” for my tastes. Thank you kindly!
Steve, you may have nailed it here. I missed it, but yes the two capacitors are the same and so are the two coils.
So, the components highlighted in red are for phase manipulation (possibly delay compensation).
The components in blue are for upper impedance variation management.
In green are for setting the level and general impedance variation management.
The component in orange is the crossover 🙂
