Acoustic Horn Design – The Easy Way (Ath4)
No, there's almost never any additional smoothing in the polars I show.
Attached is the ABEC project and my results obtained using ABEC 3.6.0b7 (64bit demo) as calculated a while ago using the script from #10,653 -
  • DS8N_ABEC_FreeStanding.zip
I saw that the setting for ABEC mesh resolution is only at 1000Hz in the script. Is that correct? I always assumed it must be at least equal to the highest frequency of interest?
That's of course true, in general. The aim here is to setup Ath to generate the mesh with a high-enough resolution already, so the nominal value in ABEC can be kept this low (i.e. it won't do any additional mesh subdivisioning, which is all it could do).
Just running your project to see if there are differences. In setting up ATH I assume not many mistakes can be done as long as it proceeds the input script...!?
That mesh issue is interesting: I was not aware that Abec/Akabak will only sub-mesh if necessary. This explains horrible computing time of some other sims I did..... :)
Hi
different...... if I run your project first I wonder that axis for observation seem a bit curious as out of axis:
Is that intended?
Gmesh I have 4.10.5. I will try to find your version online. However the scattered results remain. See e.g. radiation impedance:
Will try the "NUC" setting next....thanks for inspirations! :)
BTW, the bended board construction also allows an easy making of a big mold - I want to try concrete casting. All in one piece, including the adapter (3D printed part of the mold).
I build some floorstanders from concrete about 10 years ago.
I recommend making super lightweight concrete if you can, as stopping any boards used for forming the concrete from bending under the weight is the problem.
