Audiocontrol EQT
hello everybody
i have a pair of audiocontrol eqt mono eqs.
after having noise problems i narrowed it down and found that one of them is the cause of the noise.
can anybody guide me what is the problem with it?
thanks
What's the resistance between the input RCA shields and the output RCA shields for each EQ?
See attached.
Have you taken the board out of the noisy EQ to see if there were any burned traces on the bottom of the board?
problem solved by itself.
i believe one the switches had dirt and with the tests it made contact.
i sprayed them and everything is fine now.
by the way the quite position is isolate and not ground.
ps. the inputs are isolated with transformers, that's why rca in and out shileds measure infinite resistance.
thank you for your help.
