Dual gate MOSFETs in audio path
Hello al guys. Anybody tryed dual gate MOSFETs as audio preamplifiers? Like 40xxx series of RCA, BFxxx fron Europe and 3SKxx from japanese manufacturers.
I refer best g2 bias, load resistance and voltage gain available. Supposedly to be low noise devices?
Many thanks in advance.
Do they make for a handy one-active-component modulator? Signal on G1, second signal on G2, output G1 * G2? If so, one could use to make a 2nd harmonic generator. Never seen that done, which makes me suspect it doesnt work that way...
In a radio, do they "mix" a local oscillator with the tuned input signal, for the IF? Surprised they're still available for a "new design"!
Reactions: geraldfryjr
Joining both gates doesn't convert it in a doubler, it behaves like a single gate unit.
In many aspects, they act as pentodes. But joining the gates like a triode.
I have several of them new and recovered. All them saved in a metal can to protect them from electric fields. (I am ham radio so sometimes large fields are around me when transmitting).
I found this book freely googling. Interesting projects.
Well, a quick web search turns up all kinds of "Mixers", where a local oscillator is "mixed" with RF to produce a signal for an IF strip.
When I plug my guitar and microphone into my Behringer "mixer", the two inputs dont produce upper and lower sidebands off each others frequencies - AFAICT... Maybe my hearing is just bad 🙂
Here's one circuit where the gain is controlled by a second signal. Sounds like Amplitude Modulation to me.
I have plenty of these, but never used them for audio.
I was into long distance fm reception, and built plenty of antena preamps with dual gates.
Since this forum has no fm section...
The word "mixer" has quite different meaning in Radio and Audio.
Radio 'mixers' multiply (not always exactly).
Audio 'mixers' add (usually pretty good).
The multiplication can be a gain control. Or AM modulator. There are other ways to do these things. However radio front-ends does seem to be the main use of these things (before chip consumed that vanishing market).
AFAICT there are very few loose dual-gate MOSFETs on the market. IMHO anything they can do can be done with more generic parts that are more available.
My DUI (Device Under Investigation) is a 3SK58. It is like a 40xxx from Motorola regarding it aspect. I did a simple test jig: a source bias of 1K // 10uF, a 100K pot from the 12V supply and a 50K rehostat as load in the drain. Paradoxically, best amplifier gain was with g2 at same DC potential as source, 0.8V at the 1K source resistor and about 15K to 22K load. Then, a good 1KHz signal appeared at the drain with simetrical clipping and the drain voltage about 6VDC. Estimated gain was 60 and a pretty 8V pk to pk was obtained.
It is usualy said that maximum gm is with 4V at the g2. But posibbly this is for inductive with low DCR load. Who knows.
