What’s On the Bench Tonight (OBT)
RPi as a streamer sounds like a lot of dIY fun.
I have some Khadas SBC’s which are like really powerful Linux with AI coprocessors. I also have a Volumio image specifically made for it but have not had time to play with it yet.
I am lazy and Amazon Music HD / UHD works well for me. 🙂
OTB tonight are some RIAA loading selectors for MM/MC configurations on the Bob Carver preamp V12. 0.5% Susumu 0603 resistors and nice NP0 caps to select gain and input capacitance and impedance.
Mounts like this:
Fits on rear panel like a glove:
Interestingly, I’m starting to work on driving the LSA Phono-01 MM/MC preamp into production. It has a similar DIP switch for setting input impedance, capacitance and gain.
Busy times.
Lovely Build, X
With Khadas I would want to make it a android gaming box and play COD \ PBG with buddies
RPI with the justboom amp hat TAS5767m. was doing something that I have not enjoyed before and than having one uSD card with kodi for movies and YouTube and other uSD card for Moode was like a dream. Now Since I have assembled the My Ref Rev A - I decided to try the RPi + HIFiBerry DAC+ PCM5122 for music only duty. I may upgrade from pi3 to pi4 but in future.
I am struggling with a hiss from the pga2311 board when I go into the gain zone - I want to know if there is a way to remove the hiss (tweeter) maybe when 6” away I can hear.
Running a RPi streamer in my main system. RPi + HAT DAC + moOde into B1 + Alpha Nirvana. Works beautifully. But for me setting up the RPi was not much DIY fun. I'm an old dog now and learning curves were steep. The DIY fun part was building the Matt Garman HAT DAC. Hope to upgrade the DAC soon with another diy DAC, but the smd soldering is also nerve wrecking. Bottom line - don't grow old.
Reactions: aditya
  • don’t grow old -> wish we were Spock.
  • RPi, yes it’s a learning curve but gotta do it.
  • Soldering smd is pain as we age be it 40 or 45 or 65 but I use a wearable 5x with dual led which makes it easier. and its there on Amazon.
Good luck with the new DAC ☺️
Reactions: twocents
On the bench tonight is some computer repair. My laptop battery was bulging and pressed against the trackpad making inoperable. The K button key was broken. So it was a simple matter to open the case once you know where the screws are. You can see the old puffy balloon-like battery vs the new slim flat one. The bad K key button was swapped with a redundant ALT key. A label maker came in handy. My 2 year old HP laptop with Core i7 and 32GB RAM and 1TB SSD has been given a new lease on life.
I got all these tools out but turns out all you need is a small Philips and a guitar pick pry tool.
The insides are amazing feat of packaging:
Old battery:
New battery:
Keyboard fix:
Reactions: aditya
I got a 16GB DDR4 Ram and 1TB Samsung 980 NVMe ssd to put , i am too lazy to put those in.
8GB Ram is holding my processor back , AMD Ryzen 7 4800U
First time got a AMD CPU and i have to say i am super happy.
8 core 16 thread on a UltraBOOK is total Vodoo to me. My previous laptop was i5 4th gen [Dell XPS 15] a huge upgrade.
I still kept my old one as it can run Windows XP [got all driver] and spme of my software doesnt like anything newer than XP.
Old battery:
New battery:
Keyboard fix:
@xrk971
That motherboard looks almost like my i5 8th gen dell 7000 Inspiron 2in1’s did intel give these guys some reference design ? Will share my motherboards pic a little later.
Only thing that I didn’t like with EVO 980 is if we use performance mode the warranty is void.
I have two drives Evo 980 500gb and evo 860 in the laptop.
Working on simple soft start with dual auxiliary supply which also powers my micro and a relay.
Need to get better relays - marking erased with IPA 😬, will test further with TOROID , dry run worked.
Reactions: xrk971
