Thank you sir63 / 37
It has a lower melting point than Pb-free solder and has the best eutectic properties. Google it. Don't use it on commercial designs if they are being sold in the EU.
So I could use 63/37 to solder film & foil Capacitors on my Amplifier Pre-ampThank you sir
How do I find the Pre-amp Section/circuitry tone control on my Sony home theatre intergrated amplifier
Look at the circuit diagram or block diagrams in the service manual.
It has specific uses as in jewellery, etc. but is not used in Electronics building.Solder with bismuth. Melting point 138deg
This can be a great idea to save sensitive components. Just clip the tweezers on the lead on the component side of the joint being soldered. Use the thinnest solder you can manage as it melts quicker than thick solder so you don’t have to sit there with the iron blazing for extra time melting it. Pre tin the lead being soldered with a quick light coat of solder to aid good flow. Use your best judgement as to how much heat is too much heat.its not solder, but maybe you can use Heat Sink Tweezers
Pleasure Thank You Very Much Truely Appreciate ItLook at the circuit diagram or block diagrams in the service manual.
If you are planning to change components in a home theatre amplifier, they will be very small
surface mount parts, and difficult to work with. Not recommended to attempt, unless you have
considerable previous experience, as well as the proper equipment.
Those things are cheap, and parts not available.
Where are you located?
What is the problem in your unit?
If you need to, get it done by a person who repairs cell phones, or computer mother boards.
They will have the tools, materials, and above all experience in doing it.
For SMD work, combination pastes with flux and solder powder are sold, it is applied to the joint, then hot air from work station is used to make the joint.
No small polypropylene and polystyrene like womanNot to be recommended, the parts are unlikely to fit properly, and may damage the board.
It is entirely possible to solder SMD components by hand with nothing more than a standard soldering (with a fine tip,) some thin solder (0.5mm) and a pair of pointed tweezers.
With experience, but not when trying to use a film and foil capacitor in place of the original.
Indium silver solder 143C.40C lower than 63/37. Indium/Tin 118C
https://www.digikey.com/en/product-...MI3_Gl4e2y-gIVfolaBR1oCANmEAAYAyAAEgLNDfD_BwE
There’s a smt paste that melts at 138degC (lower than leaded). Same with flux too.It has specific uses as in jewellery, etc. but is not used in Electronics building.
- Design & Build
- Equipment & Tools
- What is the best type solder for heat sensitive components
