Simplicity and elegance, feedback wanted!
First of all, a conditionally stable amp is the last thing we want, don’t we ?
Ok.
Noninverting unconditionally stable amp mostly anyway have different source resistances seen from its inputs. Now, just think, do it have equal voltage drop caused by input bias current? Do this drop equal to differential and common mode? Do this drop are equal through working signal voltage swing? Do this drop are equat through input common-mode range?
So, what amp do you want now?
Have no doubt, i'll prefer to keep amp inside known stability conditions and have +60 dB feedback handicap than use unconditionally stable miller-compensated first-order one.
Regarding Output Stage Protection Circuit
I might be wrong and I don't have access to any simulator to check it, but here's how I see it, the protection circuit for the output FET stage doesn't work as one might think, those 2 transistors Q15, Q16, and 2 diodes D3, D4, supposed to sense the voltage fall over the source resistors at 0,1 Ohm in the occurrence of a short at the output do nothing, or, almost nothing, because as we will soon see they do "protect" but in a peculiar way.
The lower side of the Vbe multiplier circuit, which is biasing the output stage, is during positive cycle clamped to the output through lower over current protection transistors collector-base diode + lower diode + source-R (Q16 + D4 + R26).
And vice-verse during negative output voltage cycle, the higher side of the Vbe multiplier circuit is clamped to the output through the upper transistors collector-base diode + upper diode + source-R (Q15 + D3 + R24), hence these two transistors do not act on the voltage fall over output FET source resistors more than two passive diodes via their base-collector diode.
And the reason the output clips harder for positive cycle is because the N-ch FET's have lower Vgs threshold than P-ch FET's, in any case the Vgs drive is always so low due to the clamping that the output FET's becomes self limiting without any protection circuit.
To make the output protection circuit (consisting of Q15, Q16, D3 and D4) engage during a short, we would need at the very least some 0,6 Volt voltage fall for each of ALL 4 devices (Q15, Q16, D3 and D4), ie. 2,4 Volt, and 2,4V over R24 alone equals to 24 Ampere for one output device, which doesn't happen due to the clamping effect explained above, ie. the protection circuit doesn't work as expected.
SSassen, can you draw a rough sketch block diagram of your final 'balanced mode' application? I'm busy with a balanced bridge Hiraga with an unbalanced input, hence this question.
Apologies for the late reply, work caught up with me 😱...
Not entirely sure what you mean, the schematic as posted shows the balanced mode operation, which only applies to the input really, the output of the amplifier is single ended.
Alright, on with the show! I was rummaging through my parts drawer and found some spare transistors, a few LEDs, some resistors and an inductor and figured I throw them in for good measure. We've dropped THD 20K at 100W in 8R down by another order of magnitude (0.000081%), but that's just in the simulator of course. Notable changes are:
1) L4 a 10uH inductor that helps to up the loop gain at lower frequencies.
2) Q27 and Q28 to make the input a complimentary feedback pair (Sziklai).
3) Cascoded the current mirror for the input pair.
4) Cascoded the VAS/TIS section at the same time, a genuine two for one special!
5) Pick off points for the feedback network across the output resistors, hopefully dealing with rail distortion.
And yes, I know I'm suffering from feature creep, I keep telling myself that a few more transistors won't break the bank, and they won't, and I know I'm straying from the path of KISS again, you guys better reel me in before I go off the deep end again!
Does 2) improve anything in simulation?
In my builds I got good results with 270ohm for 20N20 and 180 for 20P20.
I also added 15p between each gate and drain.
And 15n decoupling very close to each drain.
Never seen such low 20THD sim......
Same here, but..
my REW measurements came out better than the sim 😀
  • LatFETAmp_2019_08_15_sine.asc
