For Sale DIY Raspberry Pi KIT
Things you have for sale.
* SOLD OUT, THANKS VERY MUCH FOR YOUR INTEREST *
Hello everyone, I'm selling the DIY Raspberry Pi KIT from Hong Kong. The KIT includes all of the necessary parts to build a Raspberry Pi Player / Streamer with built-in linear power supply. You will need some basic soldering skills and it takes about 2 to 3 hours to assemble the parts.
Case:
-Aluminum alloy fabricated with CNC and LASER cut
-Opening at the bottom, can change OS with ease
-Dimensions:215(W) x 100(H) x 245(D)
-Support standard D-type sockets
-RCA jacks included
-Native support for Allo Boss 2 DAC HAT
Power:
-40VA audio grade R-type transformer, 5A output
-Built-in LPS, 0.1% load regulation, 80dB PSRR (120Hz)
-8x Nichicon FW Series capacitors
-Ultra low ESR,CLC filtering topology,WIMA MKP10 and TAN CAP for final decoupling
Note: Supports Raspbery Pi 4B ONLY
Touch screen is included
No Raspberry Pi or DAC included
YouTube demo:
BOM:
https://drive.google.com/file/d/1yL...nQ5-xRGCwqmKizoNdenruWd9Agf4MbQsQ2C4YxArCo_AM
Price:
HKD1400 plus shipping. No VAT included.
PayPal accepted with 7% service charge.
My blog:
https://smp-gadgets.blogspot.com
Does the display works with Roon if a supported distro is installed? Let's say Ropieee or Volumio with Roon plugin?
IT uses the raspberry pi display connector, which is a good sign. The pecanpi player also uses a non-official display hooked to that buss and it works with ropieee. I'm about to order one and if you are patient, I'll let you know if it works with ropieee, but as you can see I'm a betting man and I'm going to bite.
Sheldon
Is it possible to install a HiFiBerry Digi2 Pro DAC with it ?? How much to send it to sydney Australia?
Hi, Yes, it's possible. I replied you in Youtube. Please see below:
Hi, I think it's not difficult to install the the "Hifiberry Digi2 Pro" in it. Personally I don't own this Hifiberry DDC but it should be simple by just soldering the BNC and COAXIAL outputs to the D-type sockets at the back panel.
Here's a reference with Allo Digione Sig:
https://www.facebook.com/photo?fbid=572447707908913&set=pcb.572448891242128
Unfortunately this KIT is sold out. There is a new version with 7" QLED display, please check it out at: https://carousell.app.link/qxVaTTbhXsb
Thank you for your reply.
That was the best kit with my preferred silver color and reasonable price.. Is there any possibility to re-stock that kit(https://www.carousell.com.hk/p/diy-...rer_request_id=b6WHc9dcQiLQYuKJ&t-tap_index=3 ) in future???
Thanks for your interest. I can try to order a small quantity from the aluminum factory. But before that, would you please let me know if the shipping cost to Sydney HKD438 is OK for you? The total cost would be (1400+438)*1.07=1967 HKD. Thanks.
Not associated with this guy other than being a customer. I have his older kit that started this thread, and it's been working well for me for a couple months now and I'm quite pleased with it. It does require some through-hole PCB soldering, but if you are comfortable with that, it comes together nicely. Very well packed and quick shipping.
Sheldon
