Continuing from post #260....
...and please don't put your words on my mouth. It's a bad habit! Where i said that uninsulated package is the reason for rejection STM parts?? This is the first time i'm thinking of using the Ignore button. Much better option.
Where on earth do you get that from? It "disappeared" because market demand reduced supply to zero. In case you missed it, the pandemic caused manufacturers to dramatically reduce production. They're now doing their best to catch up.Even more in my favour: LM3886 practically disappeared (this very thread proves so) , obviously it stopped being a good seller, manufacturers lost interest in it.
As for the differences between the LM3886T and LM3886TF: The TF does have higher thermal resistance from junction to case. That part is true. However, the only time I have been able to measure any difference in performance between the T and the TF is with heat sink temperatures around 100 ºC where the LM3886T will perform better. So unless you routinely run your heat sinks that hot there is no practical reason to use the T version - at least not in a DIY build. I use the T version with Keratherm pads in my finished amplifier modules to avoid having my assembly guys mess with thermal goop.
Tom
I missed that part while replying. Specifically one thing i want to mention that here some people are good in twisting words & subject. I repeat again, at the moment there is no good alternative of class-ab chipamp like lm3886. I already proved that with data.
"I already proved that with data." Where was that?
Anyway , tda7293 is a great chip, a good design will "prove" it ,
take a look here: https://www.kaltecs.com/tda7293-composite-amplifier/
Typical Audiophool statement.1)Of course i CAN, listening experience is the most IMPORTANT thing! Many amplifiers are good only in PAPER but not in REALITY!
"Proof is against me but I still trust my judgement against anything else"
Yes you do, we never doubted that 😉
I changed nothing.2) I have very good memory Mr.fahey & i think you CHANGED your stand! Lol !
My posture there is that you can´t pull 100W RMS out of 2x TO220 cases side by side and I maintain it.
Nowhere did I state 100W is possible or safe, all my examples were both of them putting out 50W RMS, at which TDA7294 will last forever.
Can you read english?9) Ridiculous! You are comparing a venerable age old 60's transistor with a much more modern integrated circuit. If you want to.. compare in same category.
I compared 2N3055 to modern transistors
Which is NEVER achievable driving any real world load (hint: speakers),precisely thanks toparanoid SPIKE protection.10) Now you're contradicting your own words! Anyway according to their datasheet tda7294 has a peak current capability of 10ampere, whereas 11.5 ampere for lm3886 !!
I have heard it triggered many times by difficult lods and it sounds ugly
No, I don´t claim to hear 0.1% distortion as you seem to, but anybody can hear 30-40% horribly chopped waveform caused by triggered VI limiters ... like SPIKE does.
I suggest not mixing drinks with Forum answers ... it´s easy to notice 😉Now it's time for a drink
Cool, hope you can keep your word.and please i don't want to continue anymore, tnx in advance
You´re welcome.
Piling up prejudice over prejudice ... and you want to be taken seriously?Oh i see, you're from Europe. So it's hard for you to digest the truth.
Tell that to Logitech (see post #258) .... maybe they have little or no experience? 😉there is no good alternative of class-ab chipamp like lm3886
People from the Kolkata area tend to think they are smart, everybody else is stupid.
No details of test equipment or speakers were provided, so it seems his opinion is all he has at this point.
The importance of speakers, and a description of listening area (room treatment), have been ignored.
ST and TI may be competitors / overlapping in some areas, but it seems ST has a wider range available in different outputs in Class AB compared to TI, and also for the 12V (car) market.
In any case, Class D and earbuds seem to be the future, so manufacturers will bear that in mind for development and production planning.
And as always, volumes are important, 49810 series was discontinued for that reason alone by TI.
See post #257, where i proved that lm3886 is far better than tda7294!"I already proved that with data." Where was that?
I admit in paper it looks good. But subjectively tda7294 & 93 both sounds the same. Not my cup of tea as i said before.Anyway , tda7293 is a great chip, a good design will "prove" it ,
Proof is against me?!! Check your glasses. In post #257 i already proved that lm3886 is much better performer than tda7294.Typical Audiophool statement.
Really? I was under impression that you were talking about reliability. Anyway at least you're admiting that ST people are good in marketing, not in performance.I changed nothing.
Of course i CAN, but i admit i'm not good in TWISTING words. It is very much evident that the price of such old parts increases over time because of their non-availabilities. ST already stopped making To3 parts & today no one uses To3 package in their new designs. On the other hand lm3886 nowhere nere obsolescence & very much recommended for new designs. Also still very popular & in huge demand.Can you read english?
"Proof is against me but i still trust my judgement againsts everything else"Which is NEVER achievable driving any real world load (hint: speakers),precisely thanks toparanoid SPIKE protection.
Lm3886 COMFORTABLY delivers 68w into 4ohm & 38watt into 8ohm load as per their claim. Do you have any evidence in contrary??
Again! I didn't mix anything. What did you notice? 🙄I suggest not mixing drinks with Forum answers ... it´s easy to notice 😉
Because some people are smarter to forced you by pulling your leg. Thank you, you're also welcome. Anyway promises are meant to be broken 😉Cool, hope you can keep your word.
You´re welcome.
Who cares? I don't expect anything from someone who change views depending on situation & i don't take such people seriously! Post #258 also proves Logitech makes CHEAPO quality powered spkrs.Piling up prejudice over prejudice ... and you want to be taken seriously?
Of course they were smarter. Do you know your history, history about indian freedom struggle?? I think you forgot the famous quote by GKG--- "What bengal thinks today, India thinks tomorrow" !!People from the Kolkata area tend to think they are smart....
It seems you're from gujraat, the homestate of our Prime minister...
https://www.google.com/amp/s/www.in...-modi-said-this-to-industry-body-4054987/amp/
Take a look at this one: https://www.diyaudio.com/community/threads/folsom-ec7293-pvi-powered-frontend-60-120w-8-4ohm.338275/
Impressive!! But still lm3886 is unbeaten, undisputed winner! A BIG thanks to Tom 😉 🙂
Btw check post #446 of your link for reliability of Tda part 😉
https://neurochrome.com/collections/power-amplifiers/products/modulus-286
Well put need to see alternatives and look into the future1) you CAN NOT tell them apart by ear alone. Period.
Don´t "listen with your eyes".
2) "much better inbuilt protection circuitry" Where do you pull that from?
Both have robust short, thermal and overload protection, to boot 7294 has MosFet outputs, which by definition are stronger than bipolars (hint: better SOA)
3) insulated package is a "feature" loved by noobs and cheap manufacturers, it simplifies assembly and saves a few cents ... to the costof heavy degradation in thermal dissipation and power output.
Give me metal backs, mica and grease any day of the week.
Which is the higher quality option of the two.
4)
Nonsense, it has no influence on sound.
It degrades thermal and power performance of course.
5)
Hey, are we getting aggressive and insulting now?
6)
Nonsense/imaginary attribute.
BOTH are very high gain very high NFB power Op Amps, very flat response in the Audio band, very high damping, none can be boomier than the other, which would need either a low frequency peak or low damping ... none of that happens.
7)
So you rely on magic/mojo/perceived prestige .... nothing real or measurable.
LM3886 is very good, but was about the only game in town way back then .... now the new kid in the block is eating its breakfast.
8)
WHICH experience?
Anything you did personally or just lots of Forum reading and lots of YT watching?
"3886 for hifi stereos, surround sound amplifiers" .... you mean 10 years ago, when 3886 was "this wonderful new invention", no competitors (except clumsy expensive STK modules which it partly replaced) ... but then those exact same customers moved AWAY from Class AB, period, into Class D which today rules that market.
TDA7294 has not replaced it not because it´s "worse", quite the contrary, simply because Market changed.
U$10 or more is too expensive for what it offers, period, they rather switch to Class D.
Even your beloved TI did that, offering a huge array of Class D chipamps..
Yes, there is an ever shrinking market for a few 3886, and even less mad people who will pay $35-300 .... a few swallows don´t make a spring, no serious Manufacturer can base production on that.
On the other side, TDA7294, with high quality, still massive production and reasonable cost can still enjoy a few years of (commercial) life.
DIYers? "Audiophiles"? .... hey, they still sustain a microscopic (should I say picoscopic? 😉 ) market for NOS Telefunken tubes, DHT triodes, etc.
Not significative.
8)
YOU say (or imagine) so, with no solid backing.
9)
Think "Manufacturers NOT INTERESTED" plus "A few will pay anything" and you´ll understand 😉
Marketing 101.
OLD as the hills and obsolete on all counts 2N3055 demands expensive (for what it offers) U$5.50 each at Mouser .... do you think it´s as good or better than modern transistors?
10)
Ok,if you wish so:
LM3886------TDA7294
* Power into 8 ohm @+/-35V
50W------70W
* practical rail voltage:
+/- 35V ------ +/-40V
* PO Output Power (Continuous Average)
Both: THD + N = 0.1% (max) @ 50W RMS
* Noise:
Both: inaudible in normal conditions.
In all, no (significant) difference justifying to pay 3X and wait MONTHS with zero guarantee of future availablity.
In my book: "not recommended for new designs". 😱
Well, i think i can manage two or more people single handedly & of course with evidence! I already put in enough data to back myself but it seems thrashing someone in past didn't go well 🙁
One more thing, i didn't say anything BAD about STM(what i said, in context of tda72×× class-ab chipamp), which is a semiconductor giant! I use many ST product(regulators, transistors etc) with full satisfaction.
JMFaheyExcellent suggestion.
Mouser shows >5000 and almost 700 in stock (V and H versions) for U$10.50and 11.50 ... what´s not to like?
Why wait for the Unicorn when a perfectly good workhorse is cheap and abbundant?
Maybe all designers suffering in this thread should switch specified IC (easy peasy) and solve all their problems, specially the one designing for a third party as a consultant.
They also show 333 STA540 at U$6.50 each.
Now I understand why Orange Microterror uses half of a 540 as a power amplifier, leaving other half "wasted" .... even so it´s easier and cheaper than looking for "the proper one"
Personally I think in "black boxes" when designing: signal in > [blackbox] > signal/power out.
Not "married" to any specific type , brand or model, only worried about getting the job done.
Saved my bacon countless times.
LM3886 is a killer amplifier, but if not available ......
And if another can do its job .........
It´s a no brainer.
You are wrong.
TDA7294 can do exactly the same job, if not better.
have you used TDA540's - think they are good for a simple project. I was running them with a Dayton Classic DC-130AS-8 bookshelf.
not a lot of power but I was just testing some other thing and needed an amp to listen in.
I had used them in bridged mode for Stereo.
What I liked is we could use up to 19Volts for 8Ohms - this could be TDA7379 re-packaged maybe.
Like I said earlier, buy a populated board with heat sink, and then change what components you feel like AFTER testing.
Less work than doing it yourself, and then fault finding if there is an issue. Heat sink also seems to be an issue in some countries.
Same advice for other types of amps in general.
There are decent to terrible copies of the chips, the board seller would tend to use a better quality.
And, please try to use a type which is not in short supply, or end of life.
Of course, there is always the second hand market, so your decision, whether you want to tinker with something, build it or listen to music.
Personally I never look for electronic components at Amazon.com….Has anbody looked at the Amazon offerings? Are Chinese clones? Are they real?
Better chances on ebay, but when I say ebay I don’t mean China, no offense Chinese people, I will try to find local honest sellers .
There are many Chinese and Taiwanese copies of the older 5 pin chip amps, some legal, some dubious.
3886 copies have not come to my attention.
But like above, stick to known local suppliers, at least you have some dispute resolution available if you feel the item is not suitable.
Why don't you buy which #Asuslover offering. LM3876 is also a nice sounding amplifier, pin compatible with LM3886. Same bipolar tech & with inbuilt Spike protection circuitry.Has anbody looked at the Amazon offerings? Are Chinese clones? Are they real?
Absolute worst case, a brick through their window glass will be a profound statement about being cheated.at least you have some dispute resolution available
Not possible with a vendor 18000 km away.
Oh, I do ... who doesn´t?
No matter what you sell.
What matters is absolute percentage ... 1 or 2% means you are doing very well; problem is that 1 or 2% are often (not always) very LOUD, complain on Forums, etc.
Some have unrealistic expectations, some are paranoid and distrust everything.
Often helping somebody is taken the opposite way.
- Chip Amps
- What's going on with LM3886 availability?
