305Vdc HV regulator adjustable via zener diode too slow 7seconds
I think I keep 305VDC as this and separate fixed bias to another small board.
however, the fixed bias can't adjust voltage of -55 to -65VDC for 45 tube. If need about 10 volt range adjustable @very low current 1mA how to?
It always come out at -60.14VDC
The first schematic is very confusing with the ground point after the pos rectifier but wanting a neg voltage and two series pass devices.
Why all the complexity? Just use a schematic you would normally use for a pos voltage, but reverse the rectifier (and change the pass device of course).
Reversed diode and grounding the bottom of the capacitor as you would normally do. Then you have a neg voltage wrt ground, and then put the source follower after it, similarly to the 2nd schematic.
Jan
Jan
Did not work. a lot of noise. failed but another one work no noise (but fixed at - 60VDC can not adjust voltage)
simple Fixed bias scheme might better. adjust using zener diode (not effective but small board)
If anyone can adjust voltage please recommend Thank you.
I couldnt sleep very well, so i breadboarded a regulator for the HV for you. My main problem with your regulator was two things:
A mosfet leaks slightly from gate to source, say .5mA to account for this you need a relatively low value of resistance from B+ to gate, by using a 2mA current source this is taken care of and the current source will work down to about 5V
secondly one wants to keep the dissipation out of the driver transistor this is better for voltage stability, i did this by building a cascode out of a high gain BC547 and a MJE340.
Attached the schematic, and a picture of the breadboarded regulator, with resistor instead of current source(I ran out of MJE350)
V4LVE
Reactions: denny9167
V4LVE
Oh thank you very much. Politely bow to your help. I will try to simulate yours in LTspice again
Have you seen the Pmillet shunt bias regulator? Its got what you need in terms of adjust-ability and is thoroughly tested.
http://www.pmillett.com/bias_supply.html
Yes, i am big fan of him. However i have try simulate his schematic in LTSPICE but failed. I am also big fan of T-Reg v.5 high voltage but when I try simulate. It failed. I can do simple LTspice (basic knowledge) hence difficult schematic, I failed. I will try again but my eyes sore with 4 hrs of LTSPICE. I might need to go University to ask some engineer students to help me soon. 🙂
Reactions: jan.didden
Well you can just build it, no need to get hung up on LTspice ;-)
It's a proven design.
Jan
Reactions: supernut
