2 DACS on eBay
Warm and smooth without fatigue? Depending on how picky you are about those requirements there may or may not be a good solution that you will find satisfactory. Maybe you could rank which things are most important to you, and what your budget is? Also if there is a dac you were happy with the past and or one you weren't happy with maybe that would be helpful to know.
Otherwise, I would say that to get everything you asked for in a combination that sounds really good you might find one under $10k - $15k, but probably more than $5k. If your budget is more like $100 - $150, probably you will have to be more specific about what you don't want the most. Is warm more important that smooth? How much of a problem would fatiguing be? Those sorts of tradeoffs.
Also, do you need hi-res? DSD? Just want to play CDs?
It should probably work with the default UAC1 USB sound drivers, but maybe not. That might mean you would be limited to 48kHz maximum sample rate, and Windows will resample all sound to the 'Control Panel/Sound Device' default sample rate and bit-depth you specify as in the pic below. For that dac you might want to try setting it to 16/44 (CD Quality).
