I have started some breadboard tests for a fully balanced TDA1541 DAC.
finished Receiverboard: CS8414
finished Board to split I2S signal into R + L (circuit see attachment)
Actually TDA1541 is configured in the usual way. (see attachment.)
output +/- for balanced should be AOR and AOL right?
Are my suggestions correct or has something to be changed?
How would be the I/V-restitor circuit?
2x30Ohm to ground for XLR?
Many thanks in advance for your support
Can't say anything to your schematic, but have you considered to get one of those boards:
https://de.aliexpress.com/item/1005...00022232760794!sea&curPageLogUid=vF42jVLRL5Dv
Balanced option over simultanious mode ready made...
Not sure what you are after but neither of the schematics shown do much to move things forward. Perhaps the board in post #2 is a better idea.
Probably a good idea as it is easier to implement.Can't say anything to your schematic, but have you considered to get one of those boards:
https://de.aliexpress.com/item/1005002798248094.html?spm=a2g0o.productlist.0.0.c6681fddPdnh2x&algo_pvid=3e364dc0-c98d-48e8-ae09-73e5a725ab46&algo_exp_id=3e364dc0-c98d-48e8-ae09-73e5a725ab46-3&pdp_ext_f={"sku_id":"12000022232760794"}&pdp_npi=2@dis!EUR!44.06!22.03!!!!!@210318c216600614220243463e1813!12000022232760794!sea&curPageLogUid=vF42jVLRL5Dv
By the way, how should the TDAs be implement in which mode:
Simulteanious OB/TWC to - 5V?
Which mode should be used for the CS8414 or 8412? See attached chart.
Thank you very much
I was afraid my post is misunderstanding.Not sure what you are after but neither of the schematics shown do much to move things forward. Perhaps the board in post #2 is a better idea.
Hope my feedback to weissi clearifies some of my questions.
Thank you anyway
