What's going on with LM3886 availability?
yes - I got an order in quick. They were rationing them to 10 per person though 😆
"I have been buying fakes!"
"were way cheaper than digikey prices."
"behaved the same and you couldnt really tell the sound apart"
Why am I trying to convince people not to buy the fakes , when they enjoy saving money and they think the fakes behave/sound the same as the authentic ones?
Peace out!
yeah, it seems you haven’t gauged your audience well. You would think that here, where the time and skill involved in all aspects of the supply chain should be known and appreciated; it still becomes all about money. Why should Asia care about our lofty ideals of intellectual property, when clearly it matters not to the customer.
that being said, they clearly won’t understand the full picture, until the entire high performance linear audio chip supply chain becomes untenable and ceases to exist. That is before we even talk about the self indulgences allowed designers in the 80’s-90’s when those in charge, were one and the same, or at least speaking such a different language to the bean counters, they needn’t worry.
im not sure such conditions will ever exist again in/for audio. Some other field of endeavour/ will have its turn.
Also, I guess most (stable) things exhibit low THD inside a closed low distortion loop and don’t need to use something high performance with that placement. If the control loop is good.
Not all will share that view; nor should they need to.
As a small manufacturer, I couldn´t care less about who made the chip or what´s inside, for me (and I guess to most designers, at least commercial ones) it is a "black box", which is fed "X" V rails, gets signal in and can supply expected voltage and current swing into a load, period.
Whether its distortion is 0.2% , 0.002% or 0.00000000000002% is irrelevant to end user, who will NOT hear any difference.
Same whether response is 20Hz to 20kHz , 2Hz to 200kHz or 0.2Hz to 2MHz.
Of course, as you point out, it is stable, and I add: does not overheat or explode or limits current to less than needed.
Given that (otherwise it´s useless), yes, price and availability becomes THE key parameter, why not?
PS: and yes, the control loop will be good, what´s more linear than 2 resistors and 1 capacitor?
PS2: resistor/capacitor/cable/solder/UFO fanatics and acolytes do not need to reply 😉
Reactions: aditya and krivium
Fake?? I don't think so...and yes, was way cheaper than digikey & mouser (don't ask how? :scratch:). But the situation has changed! Now it is almost impossible to get original lm3886 here in indian market.
Sounds excellent & inbuilt spike protection circuitry works like a charm! Very robust performance! Then(around 2017-19) the price was little more than $3 each. I made many stereos for my friends & till now not a single failure. That's why i'm 100% sure that i have the originals. Anyway i still regret for not buying some non-insulated package :bawling:
The patent expires indeed after a certain period of time , then other companies will try to clone that product , those are NOT original product, those are clones .
Since most of these companies will print the original company Logo on the cloned chips , that's a red flag, I call those chips 100% fakes .
About UTC chips, I have some of them , never tried them , I cannot say much.
The chip on the left is fake , next is UTC2050 chip and on the right 2 100% authentic ST chips.
I have broken my UTC TDA2050L to see die inside
Here is the video link, can't upload here due to diyaudio don't allow it for bigger files to upload
Here UTC TDA2050L
Reactions: NanoFarad
Thanks vipin for this informative post. But this thread is about lm3886, if you can then share some info about that.
Best Regards.
I have LM3886TF ICs but no failure yet, with them and you know it's very difficult to get LM3886TF these days, so I can't just break open my LM3886TF,
Although I have pictures of die LM3886TF from Facebook, John Widhi
Can't say what was wrong with ICs, but they looked very suspicious due to lot code and date code format of National Semiconductor, although NS had 4 digits coding format too,so can't judge it ,but no one in right in the head broke open their ICs without any failure
Disclaimer: I don't own these pictures, and these pictures are very old, about 5 years or something similar
...so I can't just break open my LM3886TF...
was expecting the same line 🤣
I'm with you :clown:
Old batch of 3886 had white colour printing...but most fakes are the same type too & yet to see a laser marked fake. So it's hard to know which one is original.
Edit- but those 3886 looks legit to me (post 196)
