Modify PAM8403 and TPA3116D2 to high watt
I have implemented PAM8403 and TPA3116D2. Let's use the PWM signal to increase the high volts in the circuit I designed. It works well. I recommend it to work in the line, the short range speakers are safe and sound good. But if using a long cable, it should use a filter core.
This is the PCB
This is the PCB that I designed to work with these two numbers.
  • Full PWM Audio Modify.pdf
Test +filter coil
TPA3116D2 to high watt +filter coil test.
No feedback, offset 73mV
Behind the filter core is a SPWM wave that changes according to the audio signal. It causes the carrier to be completely wiped out. And this TPA will resist clipping in the volt peak.
There are still a number of numbers that can increase the wattage to that high. and there are few that can solve the frequency
