Mark Levinson 333
Ladies and Gentlemen
I have a defective Mark Levinson 333 here, which unfortunately has a couple of output stage transistors that are defective. Now I've swapped them all (all paired with a Tektronix 576).
But now I would have to set the quiescent current of the output stage, while the circuit diagram I have says that a voltage of 34mV should be set between points A and B. Is it correct?
Or should this value be set from point A to GND and point B to GND?
What is the difference between the 333 and the 333.5 ??
It would be nice if anyone could help me
YES
