Ladies and Gentlemen
I have a defective Mark Levinson 333 here, which unfortunately has a couple of output stage transistors that are defective. Now I've swapped them all (all paired with a Tektronix 576).
But now I would have to set the quiescent current of the output stage, while the circuit diagram I have says that a voltage of 34mV should be set between points A and B. Is it correct?
Or should this value be set from point A to GND and point B to GND?
What is the difference between the 333 and the 333.5 ??
It would be nice if anyone could help me
That's exactly what the note says. The note does not say GND anywhere.says that a voltage of 34mV should be set between points A and B. Is it correct?
says that a voltage of 34mV should be set between points A and B. Is it correct?Ladies and Gentlemen
YES
- Mark Levinson 333
