Rockford Fosgate Power 400a4
Picture: Scope setting 0.2 V/div 0.5 us
#1 is C412
#2 is Ch3 Drain FET
#3 is Ch1 and Ch2 Drain FET
Ch 4 oscillation does go away with load.
Yes Channel 4 is the only one with oscillation like Pic 1 in #159
I think it was on this thread...? The problem may be due to the layout of the board, assuming that all of the components in the board, for all channels, are the same (assuming that there was no manufacturing defect in placing the parts).
There may be a solution like changing the value of a capacitor, somewhere in the circuit, but that would be time consuming. If the oscillation doesn't exist with a load, it may not be a problem that needs to be resolved.
